29273 Discussions
Visual Studio encountered an exception. This may be caused by an extension
Andrew_Smith
Valued Contributor I
On loading a fortran solution in VS2010 with IVF 12.1 update 8 I get this message. Otherwise evrything seams to work.
Attached ActivityLog.xml shows the error details
Glenn1
I can't open your xml file but I assume it is the same problem as is in the active thread #100434 which I started on11/1/2011 and last commented on yesterday (1/5/2012). http://software.intel.com/en-us/forums/showthread.php?t=100434
