29277 Discussions
Visual Studio watch window works for common blocks in x86 but not for x64
Bryan_H_1
The IFX compiler is not showing common blocks in the debugger watch window.  The code below shows DATA.Var1 as expected in the Visual Studio watch window.
PROGRAM WatchTest
STRUCTURE /S_DATA /
REAL Var1
END STRUCTURE
!COMMON /C_DATA/ DATA
RECORD /S_DATA/ DATA
DATA.Var1 = 5.0
END PROGRAM
However, if I remove the "!" to activate the COMMON block the DATA.Var1 does not show in the Visual Studio watch window.  Instead, it gives me "Invalid structure member 'Var1'".
I am using:
Intel Fortran Compiler 2024.1
Visual Studio 17.11.4
HAPPY_x86_Commonblock_WatchlistTestHAPPY_x86_Commonblock_WatchlistTestSAD_x64_CommonBlock_WatchListTestSAD_x64_CommonBlock_WatchListTestHAPPY_x64_NoCommonBlock_WatchListTestHAPPY_x64_NoCommonBlock_WatchListTest
Labels (3)
Bryan_H_1
Retested with 2025.1 and this issue is now fixed.  My thanks to all involved.
Ron_Green
You may have a fundamental misunderstanding of named common.  Common defines a storage area with global scope.  It is NOT a derived type or structure.  for COMMON / C_DATA /, the variable VAR1 is NOT a component, since DATA is not a structure.
I am surprised this even compiled for you.  I am using a prebuild of 2025.0 and ifx rejects your syntax
Data.Var1 = 5.0
with a compiler error #6535 "This variable or component must be of derived or structure type".
For Data in C_COMMON the syntax should be
   Var1 = 5.0
Correct understand of the common declaration you have is this:
There is a global storage area named "C_DATA".
In this storage area is a kind REAL variable named "Var1" that you can reference as "Var1".
It is not a structure.
Bryan_H_1
Hi Ron,
Thanks for your time.  I see my example was poorly chosen.  Please consider the updated example below.  It tries to follow the partial sample in the intel help: COMMON (intel.com),
The help does show that common blocks can include structured types.  This does run and work, the only issue is that the debugger in IFX isn't able to resolve club(1).a in the watch window.
If the example below is still not an acceptable use of COMMON, an example of the correct use of structures in COMMON blocks is greatly appreciated.
PROGRAM MAIN
STRUCTURE /member/
REAL a
END STRUCTURE
RECORD /member/ club(50)
COMMON /blocka/ club
club(1).a = 5.0
WRITE(*,*) club(1).a
END PROGRAM
andrew_4619
program main
type :: member
    sequence
    real a
end type
type(member) :: club(50)
common /blocka/ club
club(1)%a = 5.0
write(*,*) club(1)%a
end program
Out of curiosity I rewrote the sample in conforming Fortran removing the ancient and non-standard STRUCTURE/RECORD syntax to see if that was part of the problem.   I can conform that club(1)%a cannot be watched in the debugger. As noted by the OP commenting out line 9 , the common definition enables  club(1)%a to be watched.  I would  suggest this is a bug in the integrations it works in IFORT btw.
Devorah_H_Intel
I will investigate this further and update you. Thank you for your report.  @Bryan_H_1 @andrew_4619
Bryan_H_1
Hi Devorah,
Are there any status updates you can share, or any issue/bug tracking link I can follow?  Thanks.
Devorah_H_Intel
@Bryan_H_1 wrote:
Hi Devorah,
The compiler engineering team is fixing the case. The fix is targeted for the 2025.1 version of the compiler since it is too late for the 2025.0 release.
Bryan_H_1
Approximately when will 2025.1 be released?
Ron_Green
End of March hopefully, else early April
Bryan_H_1
andrew_4619
I should have noted also that the IFORT/IFX tests were both 64 bit.
JohnNichols
Valued Contributor III
program main
    implicit none
type :: member
    sequence
    real a
end type
real g
club(1)%a = 5.0
g = club(1)%a
end program
A simple workaround.
JohnNichols
program main
    implicit none
type :: member
    sequence
    real a
end type
real g
club(1)%a = 5.0
g = club(1)%a
end program
This also works and avoids using commons that are not a good idea now.
andrew_4619
The "workaround" misses the point of the post. Yes I fully agree that commons are not part of a modern robust approach I have not used common for over 20 years.  However of all the reasons a user might have for refactoring a huge existing codebase to remove commons I am not convinced that the debugger not quite working correctly in displaying some common vars is one of the best reasons.  ASSOCIATE might be a better "workaround" as it does not involve copying data to local vars.
JohnNichols
No, the original author indicated the problem. They can wait for the Intel Solution, and do nothing useful with watch or
they can use a local assignment, which is one way or an associate which I agree is a slightly cooler solution and one  the infamous mece-j4 taught me many years ago, paying homage to the Great Queen song, In the year of '39.
Do they need a quick fix or a long fix?
After playing with a lot of modules, etc, I can now see the common's concept sneaking back into C#.
But commons have problems.
