29649 Discussions
Visual fortran dll with visual basic
inasiopo
I am new to mixed language programming. I have made a fortran dll file, and I am trying to use it from basic. I made it work by reading the mixed-language-help but i have a problem. When i run my vb program from te visual basic developper studio i can not have any result! Only if i make my project executable and run the exe i can have the results.
In other words only an .exe file can work with the dll.!!
Can you help me with this?
thank you in advance for any answer
Elias
g_f_thomas
I sense that you're working with VB5/6 which has its own IDE and CVF which uses DevStudio 98 {or is it Visual Studio 6, no matter). Every DLL needs a client, usually an EXE. Compile your VB exe with debug symbols. Debug your DLL in the VS 6 IDE (not the VB IDE which you know is giving you problems) using the VB exe as client. You should be able to debug both your exe and dllin the VS IDE.
Gerry
