I just installed everything on Vista, and now I get this message about the license file. Help tells me wheere it shoudl be, and it's there, but I still can't compile. I did not have this problem when I installed previously on Vista RC2.
Must be an easy fix for this, but I cna't find it....Please tell me how to fix this.
Well, yeah, I saw that thread before. I have the beta 1 SP, which is the only difference from when I ran under Vista RC2. I don't see all those messages you say change with the beta,
I am running VS under an admin account, which I thought was suffient; it was under Vista RC2.
Perhaps I should uninstalll the beta SP.
I'll keep trying per your suggestion.
It's odd.. However a good reason might be that existing versions of flexlm were not designed for vista. Some of the previous versions were using code that wouldn't directly run on vista due to previledges.
-- Poul
We've seen this on 64-bit Vista installs. The license folder path environment variable is not being propagated through to the compiler, or it's being ignored. I copied the license file into the Bin folder for each installed compiler and it worked. My boss fixed it by jiggling the environment variable in some way but I don't have the details on it yet.
The license server has no log entry for the failed attempt in the cases I'm talking about. There could easily be more than one problem, of course.
Well, I have the same problem.
I'm running VS 2005 sp 1 with vista updateon windowsVista x64 sp 1.When I try to compile from within VS 2005, I get the lic error (no problem if I compile from command window). The environment variable points to the right lic file, but this doesn't seem to matter. As mentioned earlier in this thread, if i copy the lic file to the compiler bin directory, things work ok. However, running VS 2005 as an admin does not solve the problem. If anyone has a better fix than coping the lic file around, please post.
I had a related problem with FlexLM on vista, but that was resolved by intalling the latest utils for FlexLM (version 11.5).
cheers,
-joe
I have not yet tried VS08 to see if it behaves the same way.
