WRITE and C Strings
Nigel_Thomas
This is bugging me, as I'm porting a DOS program which returns strings from C to FORTRAN.
If I WRITE a C string either made by copying a C character constant or by using one returned from C, then whenever the NULL character is hit, a carriage return/line feed seems to be thrown.
I don't think this is reasonable - I would have thought it more reasonable to output a space?
I have to have an extra function to manipulate my strings to strip the nulls from them before writing them - which is a pain.
If anyone has another solution let me know.
The following illustrates it. compiled with 9.1
program ftest
character*20 longtext
character*12 shorttext
longtext='1234567890123456789' ! ie 19 characters
shorttext='abcdefghijkl' ! 12 characters
write(*,*)'Case 1 - bog standard Fortran strings'
write (*,20) longtext,shorttext
20 format('Long Text : ',A20,' Short Text : ',A12)
write(*,*)'Case 2 - copy a 19 char C string'
longtext='1234567890123456789'C ! ie 19 characters
write(*,*)'Case 3 - print only 19 characters of the C string'
write (*,20) longtext(:19),shorttext
stop
end
which produces
Long Text : 1234567890123456789 Short Text : abcdefghijkl
Curious. When I try your program with 9.1.025, I get:
which is what I think you want.
Nigel_Thomas
doh!
I originally had some write loops in the program & I was running
ftest | more
but just F3'd the command even after taking the write loops out.
It's more.com thats putting the carriage returns.
I've since found the bug in my original program which was down to a duff fortran strlen() routine.
Sorry for the trouble
