29273 Discussions
WRITE statement will not print the sign of a negative zero value.
Arebus
When writing out a negative zero value to the console, (-0.0) the negative sign is dropped.
For example:
S = -0.000005
 I want to print out a zero value if S is less than my threshold of 0.001
IF(ABS(S) .LT. 0.001) THEN
S=SIGN(0.0, S)
S now equals -0.0
if I now try to write out the variable S to the console using:
write(*,S) 10
10 format('S= ', F10.2)
I get:
S=  0.00
I need to preserve the sign of the original number as it represents a vector quantity.
Is this possible?
Using visual studio 2022, v17.10.5
Fortran compiler 2024.2.0, (IFX)
Fortran F77 compatibility.
TobiasK
andrew_4619
I am of the opinion that F77 does not have a minus zero concept and that came much later. Stand to be corrected....
TobiasK
@Arebus there is an older thread available here:
https://community.intel.com/t5/Intel-Fortran-Compiler/Minus-zero-instead-of-zero/td-p/1090742
can you try to use -assume minus0 ?
Arebus
Project>Properties>Configuration Properties>Fortran>Floating Point>Enable IEEE Minus Zero Support
Worked, prints out the minus sign.
