Wandering error
Mike_Z_
At compilation the following test program compiler shows error:
test.f90(45): error #5082: Syntax error, found ')' when expecting one of: <REAL_KIND_CON> <REAL_CONSTANT> <DBLPRC_CONSTANT> <DBLPRC_KIND_CON> <QUAPRC_CONSTANT> ...
program tst
implicit none
complex(16) zs, mg
zs = (1.0q0, 2.0q0)
mg = zs*( 1.000000000000000000000000000000000e000_kp + zs*( 5.772156649015328606065120900824024e-01_kp + &
     zs*(-6.558780715202538810770195151453905e-01_kp + zs*(-4.200263503409523552900393487542982e-02_kp + &
     zs*( 1.665386113822914895017007951021052e-01_kp + zs*(-4.219773455554433674820830128918739e-02_kp + &
     zs*(-9.621971527876973562114921672348199e-03_kp + zs*( 7.218943246663099542395010340446573e-03_kp + &
     zs*(-1.165167591859065112113971084018389e-03_kp + zs*(-2.152416741149509728157299630536478e-04_kp + &
     zs*( 1.280502823881161861531986263281643e-04_kp + zs*(-2.013485478078823865568939142102182e-05_kp + &
     zs*(-1.250493482142670657345359473833092e-06_kp + zs*( 1.133027231981695882374129620330745e-06_kp + &
     zs*(-2.056338416977607103450154130020573e-07_kp + zs*( 6.116095104481415817862498682855343e-09_kp + &
     zs*( 5.002007644469222930055665048059991e-09_kp + zs*(-1.181274570487020144588126565436506e-09_kp + &
     zs*( 1.043426711691100510491540332312250e-10_kp + zs*( 7.782263439905071254049937311360777e-12_kp + &
     zs*(-3.696805618642205708187815878085766e-12_kp + zs*( 5.100370287454475979015481322863232e-13_kp + &
     zs*(-2.058326053566506783222429544855237e-14_kp + zs*(-5.348122539423017982370017318727940e-15_kp + &
     zs*( 1.226778628238260790158893846622422e-15_kp + zs*(-1.181259301697458769513764586842298e-16_kp + &
     zs*( 1.186692254751600332579777242928674e-18_kp + zs*( 1.412380655318031781555803947566709e-18_kp + &
     zs*(-2.298745684435370206592478580633699e-19_kp + zs*( 1.714406321927337433383963370267257e-20_kp + &
     zs*( 1.337351730493693114864781395122268e-22_kp + zs*(-2.054233551766672789325025351355734e-22_kp + &
     zs*( 2.736030048607999844831509904330982e-23_kp + zs*(-1.732356445910516639057428451564780e-24_kp + &
     zs*(-2.360619024499287287343450735427531e-26_kp + zs*( 1.864982941717294430718413161878667e-26_kp + &
     zs*(-2.218095624207197204399716913626860e-27_kp + zs*( 1.297781974947993668824414486330594e-28_kp + &
     zs*( 1.180697474966528406222745415509972e-30_kp + zs*(-1.124584349277088090293654674261440e-30_kp + &
     zs*( 1.277085175140866203990206677751125e-31_kp + zs*(-7.391451169615140823461289330108553e-33_kp + &
     zs*( 1.134750257554215760954165259469306e-35_kp + zs*( 4.639134641058722029944804907952228e-35_kp + &
     zs*(-5.347336818439198875077418196709893e-36_kp + zs*( 3.207995923613352622861237279082794e-37_kp + &
     zs*(-4.445829736550756882101590352124644e-39_kp + zs*(-1.311174518881988712901058494389922e-39_kp + &
     zs*( 1.647033352543813886818259327906394e-40_kp + zs*(-1.056233178503581218600561071538285e-41_kp + &
     zs*( 2.678442982643049478354963071890852e-43_kp + zs*( 2.424715494851782689673032938370921e-44_kp + &
     zs*(-3.736587834535612554034559121270316e-45_kp + zs*( 2.628332980940195449089037611873639e-46_kp + &
     zs*(-9.298175995376886299601668991518173e-48_kp + zs*(-2.327942418699470598604262055622292e-49_kp + &
     zs*( 6.169620835244387420354431773150548e-50_kp + zs*(-4.928295586770989930504458682212533e-51_kp + &
     zs*( 2.183513183414510697277828498691356e-52_kp + zs*(-1.218722189147516555250452605074758e-54_kp + &
     zs*(-7.117108841662874631945652733848302e-55_kp + zs*( 6.920504054328689253528422229066270e-56_kp + &
     zs*(-3.676438468356676327679748481822479e-57_kp + zs*( 8.563098056275654327981712454743157e-59_kp + &
end program tst
pointing to 10th bracket in the penultimate line. In my big program it points to another bracket in the same line.
What's wrong?
andrew_4619
Line 44 looks blank when it should be continuation maybe?
Mike_Z_
I tried put & in blank lines -> error #5153: Illegal continuation. No valid non_commentary source following &
Two problems.
  1. You're missing a declaration of kp as a PARAMETER constant
  2. Line 43 ends with a + but there is no operand following that.
Mike_Z_
Thank you Steve, and sorry for my stupidity! Second reason. In my main program KP is declared correctly.
FortranFan
Is this what you're trying to do?  If so, use modern syntax to make it easier to read the code, especially anyone who inherits the code.
program tst
   use, intrinsic :: iso_fortran_env, only : kp => real128
   implicit none
   real(kp), parameter :: Q(*) = [        &
     1.0_kp,                                      5.772156649015328606065120900824024e-01_kp,       &
     -6.558780715202538810770195151453905e-01_kp, -4.200263503409523552900393487542982e-02_kp,      &
     1.665386113822914895017007951021052e-01_kp,  -4.219773455554433674820830128918739e-02_kp,      &
     -9.621971527876973562114921672348199e-03_kp, 7.218943246663099542395010340446573e-03_kp,       &
     -1.165167591859065112113971084018389e-03_kp, -2.152416741149509728157299630536478e-04_kp,      &
     1.280502823881161861531986263281643e-04_kp,  -2.013485478078823865568939142102182e-05_kp,      &
     -1.250493482142670657345359473833092e-06_kp, 1.133027231981695882374129620330745e-06_kp,       &
     -2.056338416977607103450154130020573e-07_kp, 6.116095104481415817862498682855343e-09_kp,       &
     5.002007644469222930055665048059991e-09_kp,  -1.181274570487020144588126565436506e-09_kp,      &
     1.043426711691100510491540332312250e-10_kp,  7.782263439905071254049937311360777e-12_kp,       &
     -3.696805618642205708187815878085766e-12_kp, 5.100370287454475979015481322863232e-13_kp,       &
     -2.058326053566506783222429544855237e-14_kp, -5.348122539423017982370017318727940e-15_kp,      &
     1.226778628238260790158893846622422e-15_kp,  -1.181259301697458769513764586842298e-16_kp,      &
     1.186692254751600332579777242928674e-18_kp,  1.412380655318031781555803947566709e-18_kp,       &
     -2.298745684435370206592478580633699e-19_kp, 1.714406321927337433383963370267257e-20_kp,       &
     1.337351730493693114864781395122268e-22_kp,  -2.054233551766672789325025351355734e-22_kp,      &
     2.736030048607999844831509904330982e-23_kp,  -1.732356445910516639057428451564780e-24_kp,      &
     -2.360619024499287287343450735427531e-26_kp, 1.864982941717294430718413161878667e-26_kp,       &
     -2.218095624207197204399716913626860e-27_kp, 1.297781974947993668824414486330594e-28_kp,       &
     1.180697474966528406222745415509972e-30_kp,  -1.124584349277088090293654674261440e-30_kp,      &
     1.277085175140866203990206677751125e-31_kp,  -7.391451169615140823461289330108553e-33_kp,      &
     1.134750257554215760954165259469306e-35_kp,  4.639134641058722029944804907952228e-35_kp,       &
     -5.347336818439198875077418196709893e-36_kp, 3.207995923613352622861237279082794e-37_kp,       &
     -4.445829736550756882101590352124644e-39_kp, -1.311174518881988712901058494389922e-39_kp,      &
     1.647033352543813886818259327906394e-40_kp,  -1.056233178503581218600561071538285e-41_kp,      &
     2.678442982643049478354963071890852e-43_kp,  2.424715494851782689673032938370921e-44_kp,       &
     -3.736587834535612554034559121270316e-45_kp, 2.628332980940195449089037611873639e-46_kp,       &
     -9.298175995376886299601668991518173e-48_kp, -2.327942418699470598604262055622292e-49_kp,      &
     6.169620835244387420354431773150548e-50_kp,  -4.928295586770989930504458682212533e-51_kp,      &
     2.183513183414510697277828498691356e-52_kp,  -1.218722189147516555250452605074758e-54_kp,      &
     -7.117108841662874631945652733848302e-55_kp, 6.920504054328689253528422229066270e-56_kp,       &
     -3.676438468356676327679748481822479e-57_kp, 8.563098056275654327981712454743157e-59_kp  ]
   complex(kp), parameter :: zero = ( 0.0_kp, 0.0_kp )
   complex(kp), parameter :: zs = ( 1.0_kp, 2.0_kp )
   complex(kp) :: mg
   integer :: I
   mg = zero
   do I = size(Q), 1, -1
      mg = zs*(Q(I) + mg)
   end do
   print *, "mg   = ", mg
   stop
end program tst
Upon execution,
 mg   =
 (6.47307362601913450156361287401753,-0.843943840773202145488299862783640)
Press any key to continue . . .
