Warning LNK4224: /COMMENT
smk_009
Hi ,
I am creating a library by compiling few fortran files using Intel 9.1 IA32 Compiler, but when Ilink the library to createan executable it give this warning for every obj file
libgdsf90.lib(sta_aug2.obj) : warning LNK4224: /COMMENT is no longer supported; ignored
How to remove this warning? How can I remove /COMMENT directive from the obj file.
Manoj
Use a current compiler - 11.1 is the current version. You can also add /link /ignore:4224 to the end of the ifort command line that invokes the linker.
