29657 Discussions
Watching module level variables in Visual Studio
dancerchris
I am having problems with "watching" module level (defined at the specification-part, with attributes public and save). It is a pain debugging when I can't see module shared variables in a watch window. Do I need to specify the module as well rather than just highlighting the variable? Any help here would be useful.
I am using IVF 11.0.066
I am using MS Visual Studio 2005 8.0.50727.42
DavidWhite
Valued Contributor II
I believe the syntax is module name:variable name or module name::variable name One of these should work. David
dancerchris
Thanks David!! The syntax is module_name::variable_name. That worked!
couldn't find documentation on this. :(
