What causes "No such EnumMachine" error?
postaquestion
초보자
1,757 조회수
I compile demo code, then try using the debugger: ifort -g int_sin.f90;(idb) load a.out
Reading symbolic information from /home/(userid)/src/Source/PBplus/a.out...Assertion failed: !"No such EnumMachine"src/appl/hw/machine.C331
This is an unexpected condition and may indicate the presence of a defect.
If you wish to report this, please include the stack trace that follows.
Could not start process for a.out
No image loaded ... Recovering ...
0 포인트
3 응답
1,758 조회수
The only references I could find to this message in our problem database were from users of an old 9.0 version of idb and the problem went away with a 9.0 update. I could not see any explanation of what caused the error and none of the users who mentioned this error submitted a test case.
Which version of idb are you using? If it is a current version, I would recommend submitting a test case to Intel Premier Support.
0 포인트
Kevin_L_6
초급자
1,757 조회수
thanks for your reply, sorry i didn't get right back.
idb -v says it's version 9.1-24. i was able to step through the code using gdb, but couldn't print the values assumed by the variables.
how do i go about sending a test case to Intel Premier Support?
0 포인트
1,757 조회수
Start here. You could also follow the "Tech Support" link on this forum's home page or follow the instructions in the compiler release notes.
0 포인트
응답
