29565 Discussions
What does FORTRAN compiler do when a variable is in parentheses?
tclin
Good Afternoon all,
I have an old FORTRAN program which compiled just fine, but it does not make sense to me. Hope somebody out there can explain it to me. Thanks in advance.
The program declares three variables as
real*8 L, Bo, B0
and later there is the following line of code:
Bo = B0( L)
I am expecting a compiler error message, because B0 is not an array. But it compiled just fine. Can anyone explain to me how Intel compiler interpret the code? Thanks.
Tom Lin
mecej4
The meaning and effect of parentheses vary significantly with context.
In the code fragment that you showed, B0(L) is taken as a reference to a function of type REAL*8 with integer argument L.
If there is no such function provided elsewhere, you will get a linker error.
tclin
Thanks. That's my fault. Idofinea small function called B0 insde the program.
Tom Lin
