29231 Discussions
What does compiler error $6419 mean?
dajum81
I have a subroutine that calls a routine called CYCLIC that is defined as an entry point in another routine in a library.  But it gives this error: error #6419: This scalar name is invalid in this context. [CYCLIC]
I added an interface block (which wasn't in the first version)  which then gave this error: error #6623: The procedure name of the INTERFACE block conflicts with a name in the encompassing scoping unit. [CYCLIC]
This is a very old routine that has been called many times in older versions of the compiler.  Is this something new in oneAPI 2021.11?
A simplified source for the problem looks like this (only formatted to start in column 7)
SUBROUTINE TD_CYCLIC
USE USERCOMMONDATA
interface
subroutine cyclic
end subroutine
end interface
PERIOD_CYC = B__PERIOD_CYC
CONVTOL_CYC = B__CONVTOL_CYC
NLOOPS_CYC = B__NLOOPS_CYC
DAMP_CYC = B__DAMP_CYC
ANGLE_CYC = BANGLE_CYC
CALL CYCLIC
RETURN
END
dajum81
I figured out that a variable called cyclic was also created.  That causes the error!
dajum81
