29284 Discussions
What happened to BINDF90, CEPCF90, F90 and IEPCF90 libs?
Deleted_U_Intel
Hello
I wonder what happened to the libs BINDF90, CEPCF90, F90 and IEPCF90 in the new version of intel fortran
compiler. I want to upgrade from intel 6.0 to 8.0 but I need to figure out which libs I need to link in order to have the same result as using BINDF90, CEPCF90, F90 and IEPCF90.
Many thanks
Ed
cp_jain
AFAIK you should not worry about these libs.
Compiler will automatically link required libraries depending on command line options.
cp
The set of language support libraries is different in 8.0. See the User Manual for details. However, as cp_jain said, normally you don't want to name these directly - let the ifort (previously ifc/efc) command driver figure it out.
Steve
