What happened to EOF()
ferrad1
I have used this function to determine the end of file in Intel Fortran for many years:
if( .not. eof(lno)) ...
Now I am getting an error.
error #6410: This name has not been declared as an array or a function. [EOF]
Has it been removed from Intel Fortran?
andrew_4619
IS_IOSTAT_END
Elemental Intrinsic Function (Generic): Tests for an end-of-file condition.
result=IS_IOSTAT_END(i)
eof function is non-standard but I think still exists, do you have standard checking options on?
ferrad1
I have these checks on.
/check:pointer /check:bounds /check:uninit /check:arg_temp_created /check:stack
andrew_4619
Additional:
Compiling with Intel® Fortran Compiler Classic 2021.8.0 [Intel(R) 64]...
... warning #7416: Fortran 2018 does not allow this intrinsic procedure. [EOF]
but without standards it compiles ok so I have no clue what is going wrong.
ferrad1
Must be some option.  Will try from a raw project and creep up on it.
Steve_Lionel
It is an extension, not standard, so the standards warning is valid. Ron gave a pointer to the documentation.
Note that IS_IOSTAT_END that Andrew mention tests an IOSTAT value, you don't pass it a unit number.
