What is "forrtl: severe (104)" ?
bgirl_02
I got this error in linux(Ubuntu 8.04 hardy).
forrtl: severe (104): incorrect POSITION= specifier value for connected file, unit 19 .........
I also tried ACCESS insted of POSITION but same kind of error came out.
forrtl: severe (104): incorrect ACCESS= specifier value for connected file, unit 19 .........
I compiled by ver. 10.0.023 for linux.
rreis
Quoting - bgirl_02
Can you post the relevant source lines (the one where you open the file?) What are you feeding POSITION with? Generally I only specify it when I want to apped stuff to the file (like POSITION='append' ). And... do you have permissions to write the file (just checking).
Ron_Green
Quoting - rreis
Agreed: we need to see your OPEN statement for unit 19 and the READ or WRITE where this occurs.
You can compile and link with -g -traceback to find the exact source line where you crash.
ron
bgirl_02
Thanks both of you. This is open and write statement.
OPEN (19,access='append',FILE='NEW_SOUR',STATUS='unknown')
or OPEN (19,FILE='NEW_SOUR',position='append',STATUS='unknown')
WRITE (19,*) NAME, ' ', expid
Also I own the file and I have write permission as you see below.
-rw-r--r-- 1 bgirl02 bgirl02 3572 2009-04-07 22:00 NEW_SOUR
Xiaoping_D_Intel
The error was normally caused by openning the same file multiple times with inconsistent POSITION specifier. For example in your case if you have already opened the non-null file with "POSITION=REWIND" and then try to reopen it with "POSITION=APPEND" you will get such error.
rreis
you maybe right, bgirl_02, are you sure you don't have two open statments for the same file?
grep -ni OPEN *f90
would give you all the opens you use in your code...
bgirl_02
I could not find the problem, which you said, in the sources.
Actually this is not my code. The execution binary, which was compiled somewhere, worked before.
I just changed one line and, after compilation, the error came out.
So I compiled original source again, and then, the same error also came out.
By the way, I compiled same source in aother PC with 9.0 version.
Do you think this runtime error came from compiler or library?
rreis
Quoting - bgirl_02
can you compile it with gfortran, just in case ? which flags are you using?
bgirl_02
Quoting - rreis
Sorry for late.
After compiling with gfortran, when I run the execution file, following errors came out.
At line 844 of file dtau0.f
Fortran runtime error: Cannot change STATUS parameter in OPEN statement
Line 844 is same line which caused the error before.
I compiled like this
gfortran -o dtau0 dtau0.f subroutinefiles...
Ron_Green
Quoting - bgirl_02
Sorry for late.
This is also indicating that file 19 is already open by the time you get to this statement. You could try this:
close(19)
open( 19,access='append',file='NEW_SOUR',STATUS='unknown')
bgirl_02
close(19)
Thank you so much.
I think it works!
I also appreciate everybody's comment.
pramodblackbird
Thnx a lot, even I wanted an answer for the same...
