29276 Discussions
What is the effect of indirect recursion on ELEMENTAL procedures, especially finalizers?
FortranFan
The following simple code involving a linked list compiles with no errors or warnings with compiler 2015, update 2.  It seems to execute without any run-time exceptions as well.
However, you will notice the code in module m invokes a finalizer for the derived type for linked list (node_t) that has indirect recursion via clear_node_t; this is to work around the restriction in the standard that both RECURSIVE and ELEMENTAL attributes cannot be applied with subroutines.
What are the risks associated with such a workaround?
Colud the compiler do a static allocation (non-automatic) for allocatable array foo in program p and could the indirect recursion then possibly lead to a failure of some sort under some circumstances?  Note, however, I have not noticed any such issues - no memory leaks are detected nor any other run-time exceptions; I tried /heaparrays0 also.
module m
   implicit none
   private
   type, public :: node_t
      private
      type(node_t), pointer         :: m_child => null()
      character(len=:), allocatable :: m_key
   contains
      private
      procedure, pass(this) :: clear => clear_node_t
      final :: clean_node_t
      procedure, pass(this), public :: put => put_node_t
   end type node_t
contains
   recursive pure subroutine put_node_t(this, key)
      class(node_t), intent(inout) :: this
      character(len=*), intent(in) :: key
      if (allocated(this%m_key)) then
         if (this%m_key /= key) then
            if (.not. associated(this%m_child)) then
               allocate(this%m_Child)
            end if
            call put_node_t(this%m_Child, key)
         end if
      else
         this%m_key = key
      end if
      return
   end subroutine put_node_t
   pure recursive subroutine clear_node_t(this)
         deallocate(this%m_key)
      end if
      if (associated(this%m_child)) then
         deallocate(this%m_child)
         this%m_child => null()
      end if
      return
   end subroutine clear_node_t
   pure elemental subroutine clean_node_t(this)
      type(node_t), intent(inout) :: this
      call clear_node_t(this)
   end subroutine clean_node_t
end module m
program p
   use m, only : node_t
   implicit none
   type(node_t), allocatable :: foo(:)
   integer :: istat
   allocate( node_t :: foo(2), stat=istat)
   if (istat /= 0) then
      print *, " istat = ", istat
      stop
   end if
   call foo(1)%put("red")
   call foo(1)%put("green")
   call foo(2)%put("circle")
   call foo(2)%put("triangle")
   deallocate(foo, stat=istat)
   print *, " deallocate(foo): istat = ", istat
   stop
end program p
I understand Fortran 2015 lifts the restriction on RECURSIVE and ELEMENTAL but that is for the long-term.  With the current standard, is such an indirect recursion a concern?  If yes, is there any way to make the coder aware of it?
I sort-of followed the discussion in comp.lang.fortran but wasn't paying a lot of attention to it. In the example here, the compiler will likely use static allocation for the descriptor of foo, but the data will always be on the heap. I don't see what the problem with static allocation would be since the main program is never reentered. Am I missing something?
The finalizer would be called for each allocation of type node_t when it is deallocated.
That the finalizer could get recursively entered is a possible problem, but since there are no local variables in clean_node_t, the risk seems minimal. If however you had local variables in clean_node_t and it was recursively entered, that would be problematic as some of them could involve static allocation.
My take on this is that you're always taking a risk when you hide things from the compiler (or the standard). I don't see any feasible way to warn about this, especially if separate sources are involved.
FortranFan
Point well-taken.
By the way, draft Fortran 2015 says, "Procedures, including elemental procedures, can be invoked recursively by default; the RECURSIVE keyword is advisory only. The NON_RECURSIVE keyword specifies that a procedure is not recursive."
So is this change to recursive by default fully accepted in the next standard, or is it still up in the air in terms of votes?
The straw vote on recursion by default (paper 14-179, a UK proposal) was 12-1 with two undecided. I don't expect opposition to it.
