29376 Discussions
What is the effect of violating the contiguity attribute of a dummy argument?
Arjen_Markus
I am experimenting with the CONTIGUOUS attribute and I found to my surprise that passing a non-contiguous array section via a dummy argument that does have this attribute makes no difference. So I wonder if it should - for instance lead to a runtime error message - or not. I compiled the program below with the flag -check:all to see if any runtime error or warning is issued and none is (using Intel Fortran 15). The program works as if this attribute were not present.
Can someone enlighten me? (I can imagine that the attribute is recognised but does not lead to more efficient code ...)
! chktemp.f90 --
module temp
contains
subroutine mytemp( a, n )
    real, contiguous, dimension(:) :: a
    integer, intent(in) :: n
    a(1:n) = 1.0
end subroutine
end module temp
program chktemp
    use temp
    implicit none
    real, dimension(10,10) :: aha
    aha = 0.0
    call mytemp( aha(1,:), size(aha(1,:)) )
    write(*,'(10f5.2)') aha
end program chktemp
jimdempseyatthecove
Try making subroutine mytemp an external subroutine placed into a library...
and where the library is not subject to multi-file inlining (disable multi-file ipo).
I suspect that the compiler optimization of inlining the code may have circumvented you attempt at discovery as to the consequences of violation of your contract.
Jim Dempsey
Arjen_Markus
I did that - the module is now in one file and the program is in another and via a series of commands a library and a program using that library are built. But it made no difference. The program still works as if there was no CONTIGUOUS.
Lorri_M_Intel
Because the compiler knows that the dummy argument is expected to be contiguous, it makes a temporary (contiguous) array and does copy in/copy out around the routine call.
What you could try is to have a completely separate subroutine, not in a module and without an interface, and see what happens.
            --Lorri
Arjen_Markus
Thanks for the suggestion, but I need to provide an interface for the routine - I tried it without and that predictably crashed :).
Of course I can cheat a bit ... trying that now. Oh, the output is wrong now:
 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00
 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
The funny thing is I expected that the option -check:all would lead to at least messages about temporary arrays (something that does happen in a different version of the program, which I specifically set up for that type of things, as an illustration), but these did not appear.
Trying with the contiguous attribute in the interface: no warning, but the result is correct now.
Just to allow someone to repeat the experiment, here are the two source files:
! chktemp.f90 --
program chktemp
    implicit none
    interface
            real, dimension(:) :: a ! Cheat: no contiguous attribute
            integer :: n
        end subroutine mytemp
    end interface
    aha = 0.0
end program chktemp
and the code for the library:
! templib.f90 --
!module temp
!contains
    a(1:n) = 1.0
end subroutine
!end module temp
