What is the maximum array rank?
Arm_N_
I ran the program on intel visual fortran compiler,using Fortran 2003, and got this error message:
error #6204: There are too many dimensions; the maximum rank is 7.
I remembered that in the user manual the inter visual fortran compiler can handle up to the maximum rank of 15.
Could anyone please suggest this? I appreciate all answers.  Thank you very much.
Mark_Lewy
Valued Contributor I
A maximum rank of 15 is new in Fortran 2008.  The Intel Fortran Compiler has this as a feature in v15.0 (XE 2015) and claims support for up to 31 dimensions.  What version are you using, as I can't remember exactly when this got added, but it claims to have available in 13.0 update 1 (XE 2013), according to the help?
andrew_4619
Fortran 90 was a limit of 7 , fortran 2008 is a limit of 15. Current Ifort supports 15 (and I think more) are you running an old version?
Lorri_M_Intel
If you're compiling with /stand:f03, even with a recent compiler, we give a warning for rank > 7. --Lorri
mecej4
I heard from somebody that seven subscripts should be more than enough for most purposes, since the number of generalized coordinates (in mechanics) is 3 (position) + 3 (velocity) + 1 (time) = 7. The most recent Intel Fortran allows 31, but we probably have to wait for a few years before we can do something useful with arrays of such large dimensions. A "small" array of integer or real type with 31 dimensions, each of range 1:2,  would take 233 bytes. The following program runs with Intel Fortran 15.0.
program tst
implicit none
integer, parameter :: d1=1,d2=2,d3=1,d4=2,d5=1,d6=2,d7=1,d8=2,d9=1,da=2, &
                      f1=1,f2=2,f3=1,f4=2,f5=1,f6=2,f7=1,f8=2,f9=1,fa=2, &
					  g1=1,g2=2,g3=1,g4=2,g5=1,g6=2,g7=1,g8=2,g9=1,ga=2, &
					  ha=1
integer(kind=1) :: array31(d1,d2,d3,d4,d5,d6,d7,d8,d9,da, &
                           f1,f2,f3,f4,f5,f6,f7,f8,f9,fa, &
                           g1,g2,g3,g4,g5,g6,g7,g8,g9,ga, ha)
array31 = 0_1
array31(1,2,1,2,1,2,1,2,1,2,1,2,1,2,1,2,1,2,1,2, &
        1,2,1,2,1,2,1,2,1,2,1) = 127_1
write(*,*)array31
end program
You didn't say which compiler version you used. We raised the maximum rank from 7 to 31 in version 12 (Fortran 2008 specifies 15.) Lorri is correct that if you ask for standards checking, you get a warning, but not with the text you cited. So all I can guess is that you are using a VERY old compiler version.
JVanB
Valued Contributor II
program P
   use ISO_FORTRAN_ENV
   implicit none
   type T
   end type T
   type(T) A(2,2,2,2,2,2,2,2,2,2, &
!             2, & ! This would cause failure
             2)
   type U
      type(T) M(2,2,2,2,2,2,2,2,2,2, &
                2,2,2,2,2,2,2,2,2,2)
   end type U
   type(U) B(2,2,2,2,2,2,2,2,2,2, &
   A = T()
   write(*,*) size(A,kind=INT64)
   B = U(T())
   write(*,*) size(B,kind=INT64)*size( &
      B(1,1,1,1,1,1,1,1,1,1, &
        1,1,1,1,1,1,1,1,1,1)%M, &
      kind=INT64)
end program P
maxrank.obj: catastrophic error: Variable P$B.0.1 too large for NTCOFF.  Bigger
than 2GB.  Use heap instead
compilation aborted for maxrank.f90 (code 1)
Well, that's another story.... You can declare such a thing allocatable and allocate it on an 64-bit system.
Arm_N_
Sorry for insufficient information.  I think here is the version you are asking about (as in the attached)
Intel(R) Visual Fortran Compiler Integration for Microsoft Visual Studio* 2008, 11.1.3471.2008, Copyright (C) 2002-2010 Intel Corporation
Microsoft Visual Studio 2008 Version 9.0.21022.8.RTM
On the help page it said "Intel® Visual Fortran Compiler Professional Edition 11.1"
Please clarify whether this can support more than the rank of 7.  I apologize in advance if this information may be insufficient again.
andrew_4619
As Steve said in post #6 "We raised the maximum rank from 7 to 31 in version 12 " you have version 11 so rank 7 it is. 11 is pretty old by the way.
JVanB
The thing is, I don't understand the error message I got in Quote #7. How come 0 > 2 GB?
Arm_N_
Thanks a lot for all answers!  I think I need to buy a newer version.
Arjen_Markus
Repeat Offender, this is probably a wrap-around of the integer: the actual value does not fit into the default integer type and then the higher bits are chopped off. SInce the number is a power of 2, chopping of those higher bits means you are left with a trail of zero bits.
JVanB
No.
mecej4
I think that Repeat Offender's point is that type T contains no components, so an array of type T, no matter how large the dimensions declared, ought to occupy zero bytes. Likewise, any derived type that ultimately is a collection of component of type T (and nothing else) should occupy zero bytes. Correct, R.O.?
Arjen_Markus
Ah, missed that. The program below shows that such types indeed occupy zero bytes:
! zerosize.f90 --
!     How large are zero-sized types really?
program zerosize
    implicit none
    integer :: sz
    character(len=1), dimension(1) :: char
    type zero
        ! Nothing
    end type zero
    type zero_container
        type(zero) :: something
    end type zero_container
    type(zero)                :: scalar
    type(zero), dimension(10) :: array
    type(zero_container)      :: container
    write(*,*) 'Via iolength:'
    inquire( iolength=sz) scalar
    write(*,*) 'Scalar:    ', sz
    inquire( iolength=sz) array
    write(*,*) 'Array:     ', sz
    inquire( iolength=sz) container
    write(*,*) 'Container: ', sz
    write(*,*) 'Via transfer():'
    write(*,*) 'Scalar:    ', size(transfer(scalar,char))
    write(*,*) 'Array:     ', size(transfer(array,char))
    write(*,*) 'Container: ', size(transfer(container,char))
end program zerosize
Result:
 Via iolength:
 Scalar:               0
 Array:                0
 Container:            0
 Via transfer():
 Scalar:               0
 Array:                0
 Container:            0
andrew_4619
I think RO's zero size entity has >2GB elements so I suspect the compiler assumes these have a size in its checks.
Is in not all pretty  hypothetical?
jimdempseyatthecove
RE: zero size
While the data portion may be zero sized, (depending on program statements and compiler options) arrays may require array descriptors.
type(zero), dimension(:), allocatable :: array
allocate(array(10))
The size(array) would indicate 0 but the RAM requirements is that of the array descriptor.
*** Note, I do not know if the above allocate would succeed or fail. If it worked properly, the array descriptor would indicate 10 elements in a rank 1 array with size of 0.
Jim Dempsey
mecej4
Does the value returned by the intrinsic function size() include the space overhead for descriptors? My guess is 'no', but I don't know if the Fortran standard says so or otherwise. I doubt that the space consumed by descriptors is affected by the size of the array rather than by just the complexity of the object that the descriptor is associated with.
Arjen_Markus
No, size() counts the number of array elements. Adding the overhead for descriptors would be rather awkward, if only because they are an implementation detail. And it would make size() rather useless for such things as:
allocate( a(2*size(b) )
I should have noticed in RO's code that the type was zero-sized. The descriptor does not get included in the computations and is separate from the data. In the case of the error RO saw, my assumption is that this part of the compiler computed that the number of elements exceeded 2**31 and figured it could not be represented in static memory, which is true on Windows (even 64-bit). That the type is zero-sized is an amusing exception but I am not inclined to suggest a check be added for that.
If you have a derived type containing a deferred-shape array, sizeof() will give you a size that includes the descriptor(s). C_SIZEOF from ISO_C_BINDING will also do this, but in the current version this is not supported in constant expressions.
