What language would they have used
JohnNichols
Valued Contributor III
I stumbled across this little gem, it is correct - checked it with excel -- did they likely do it in Fortran and what algorithm do you think they used?
https://www.ams.org/journals/mcom/1967-21-099/S0025-5718-1967-0222008-0/S0025-5718-1967-0222008-0.pdf
This paper sets out some of the findings as well from 1967,  this is a big search and overflow would be a real issue
The two are from the aerospace co - why would they be interested in this pure math --
JohnNichols
144 = 3*3*2*2*2
There is a simple beauty to them ==
Trick is -- are there any others
Guys:
Can you take a look at the code and show me how to thread it or OMP --
JohnNichols
144 = 3*3*2*2*2*2
I made a mistake back soon
JohnNichols
if a = 2^5
b = 3^5
c = 5^5
d = 7^5
e = 11^5
f = 19^5
b*b*b + b*a*a*d + ace + df = b*b*a*a*a*a
The next ones are related by n  1,2,3,4 to the 5th power
There are no common factors in the equation and they are all primes as expected
Interesting 13 and 17 are missing
JohnNichols
if n = 1,2,3, etc
m = n^5
27^5*m = 54^5
and so on I think
JohnNichols
55 11 5
3183 1061 3
28969 491 59
85282 42641 2
85359 28453 37
This is the next one according to Wikipedia and the primes are -- so this is a primitive solution as is the first one I confirmed - the rest are non primitive.   These are really random weird primes
I had to stop the program I was searching the range to 1000 and the 7th one has a rhs of 1008.
I had a quick look online -- there are a lot of people using a lot of computer power to solve these problems.
One of the interesting methods is to assume that 7 is a element of the some of the numbers and use mod arithmetic to reduced the loops.  Neat idea - would not have caught the one above.
I would be willing to bet a steak dinner that the first element of the next one is
5* 19
7 * 19
11 * 19
and that some had factors of 2 or 3 in them
so the search could be limited to search on primes,
The primes only have 7% of the density of composite numbers
Ah well a good way to relax and wile away a few hours
mecej4
@JohnNichols :
You asked, Can you take a look at the code and show me how to thread it or OMP?
It is usually inappropriate to take a code that implements an inefficient/brute force algorithm and try to improve its performance by parallelizing the code. It is more profitable to structure the calculation to avoid unnecessary recalculations, as AndrewP noted, and to use better algorithms when those are available.
The attached program is about 150 lines of Fortran code, and uses OpenMP. On an i5-8400, it takes about 15 minutes in sequential mode, and about 5 minutes in multithreaded mode, to search for all the solutions of the (5. 1. 4) problem, for x1 from 1 to 999.  As expected, the program outputs only the lone known primitive solution, which is  (144)_5 = (27, 84, 110, 133)_5.
I rarely work on parallelization of code, so there is probably room for improvement -- I saw only a factor of 3 speed up with 6 cores.
P.S.: By readjusting the loop splits as integer :: iu(7) = [999,955,900,840,760,640,1], I found that I can reduce the run time to 150 seconds, which matches the sought sixfold speed increase with six cores.
Modified to solve the (5. 1. 5) problem, the OpenMP program reproduced the results of Table III of the paper by L.J. Lander, T.R. Parkin and J.L. Selfridge in Mathematics of Computation. Vol. 21, No. 99 (Jul., 1967), pp. 446-459. The run time on a six core i5-8400 was 31 minutes.
JohnNichols
mecej4 -- you are a treasure
mecej4
@JohnNichols
If one aspires to become a number theorist, there are many tradesperson's secrets and tricks to have in one's toolbox.
Since we spend quite a bit of time testing whether a given integer is the fifth power of an integer, there is a special partial test that can be made.
The last nybble (4 least significant bits) of a fifth power of an integer must be 0000 or the least significant bit of the integer must be 1. This property is necessary but not sufficient.
We can apply this test to dispose of failing candidates in short order. If the candidate fails the test, we give up the search and go on to the next number to test. If the candidate passes, we process it as we do at present to find if it has an integer as its fifth root.
In Subroutine SEARCH, add the following lines:
integer nyb0
!search for n integers whose 5th power equals s
if(n == 1)then
   nyb0=iand(s,15)   !new
   if(nyb0 == 0 .or. btest(nyb0,0))then !new
      call search1(s,found,im,nv,vals) !old
   else !new
      found=.false. !new
   endif !new
With this enhancement, the (5. 1. 4) run takes about 2 minutes, and the (5. 1. 5) run takes 8 minutes.
mecej4
Two years ago, I reported:
This week, I found a web page where James Waldby reports many results and other information about the "(5. 1. 5) problem". He provides source code in C for a calculation that uses better algorithms than the brute force methods discussed in this thread.
His C program, running on a single core with no OpenMP, with n limited to values less than 600, produces the results of Table III of the Lander, Parkin and Selfridge paper in less than 10 seconds.
JohnNichols
This is a nice find.  Although my second grade teacher at Belmont Infants School hammered into my young brain, nice is not a word with any meaning, use a real adjective.
The human mind finds interesting shortcuts.
I have been thinking about multiply two matrices, and the shortcuts to reduce the multiplication number.
Interesting to play in your mind.
JohnNichols
An aside note:
So as I was doing this stuff, just to take the boredom away from a terrible proposal -- a minute ago I was shelling a boiled egg, I was absentmindedly counting primes in my mind, and without thinking I used the back of the spoon handle to shell the egg.
 I also was looking at the views on this stream, so that got me thinking I wonder if someone has done a video on spooning eggs, answer a couple of hundred.
I then looked for poaching eggs, this lady has 11m views, and she does some really nifty science lessons - I was impressed - if you have grandchildren this is an excellent science lesson - do it in the kitchen
I apologize for non-Fortran, but I was thinking of Fortran when I thought about this problem.
Does that count?
The presenter cannot pronounce sieve.
POACHED EGGS | how to poach an egg (perfectly)
Jul 1, 2018
mecej4O
program jmnx
use, intrinsic :: iso_fortran_env, only: ik => int64
implicit none
integer*(ik)::i = 63403400000000_ik
print '(i18,e25.15)',i,dble(i)
end
mecej4O
Here, four years later, is a shorter program to perform the same calculation. It runs in less than one second, using just one thread:
S:\algo>type silver.f90
! 27^5 + 84^5 + 110^5 + 133^5 = 144^5
program euler
use, intrinsic :: iso_fortran_env, only: int64
implicit none
integer(int64), parameter :: nmax = 150
integer(int64) :: i,j, k, l, m
integer(int64) :: n5(nmax)
outer: do i = 1, nmax
n5(i) = i**5 !overflow when i=74
do j = 1, i
do k = 1, j
do l = 1, k
do m = 1, l
if ( n5(j)+n5(k)+n5(l)+n5(m) == n5(i) ) then
print *, "i^5 = ", n5(i)
print *, j, k, l, m, i
exit outer
end if
end do
end do
end do
end do
end do outer
end program euler
mecej4O
Your program Console100 outputs about thirty lines, each containing four numbers from the set {1,2,3,4}, sometimes with multiple copies. The program has no discernible relevance to the Euler Conjecture.
mecej4O
The statement of Euler's Conjecture clearly stipulates, "for all integers n and k greater than 1, if the sum of n many kth powers of positive integers is itself a kth power, then n is greater than or equal to k". For you to allow zero now, centuries later, is going to be a hard sell.
jimdempseyatthecove
Minor improvement
program euler
implicit none
integer(int64) :: nmax
! smallest 5th root in 63-bits will be less than
integer(int64), parameter :: nuffRoom = 2**(64/5)
integer(int64) :: n5(nuffRoom), sum, temp
! Determine the max number when working with
! signed 64-bit numbers
nmax = 2**(63/5)
temp = nmax / 2
do while( temp > 0)
    if( (nmax + temp)**5 > 0) nmax = nmax + temp
    temp = temp / 2
end do
n5(i) = i**5
do j = 1, i
do k = 1, j
do l = 1, k
do m = 1, l
sum =  n5(j)+n5(k)+n5(l)+n5(m)
if ( sum == n5(i) ) then
exit outer
end if
end do
end do
end do
end do
end do outer
end program euler
mecej4O
Jim's computed nmax = 7733, but the much smaller value nmax = 145 suffices to prove Euler's conjecture wrong. In fact, a simple statement that "the sum of the fifth powers of 27, 84, 110 and 133 equals the fifth power of 144" would have been sufficient, without any mention of any computers. The statement could have been made on January 1, 1900, and that would have been enough. No need to make the great Euler feel guilty.
mecej4O
The complete edition of Euler's Opera Omnia is planned to have about 35,000 pages across 84 volumes. As of September 2022, 80 of the 81 planned volumes (not including the correspondence) had been completed. If one of us were to learn Latin and  start reading those pages today, would that person live long enough to finish reading those 35,000 pages?
David-F8
Hi everyone
I'm over five years late to this particular party.
I was skimming through the earlier posts and noted some (albeit old) comments about run times of hours.
Back in 2022, Mr Mecej4 posted about a single threaded C program that could check all values below 600 in about 10 seconds, and more recently posted a Fortran program that could check all values below 150 in less than a second.
I appreciate that it's just an interesting diversion for most.
I've spent (invested?) some time today on a simple Fortran program that can check all values below 600 in about 5 seconds (only single threaded at this stage).  Maybe around 0.03s for the values below 150.  Happy to discuss/post more details if anyone is interested.
mecej4O
Please do post your code, I'm definitely interested. Thanks.
Steve_Lionel
Here is the thread @mecej4O mentions (he started it there) - I found it fascinating to follow along as different people suggested approaches.
Euler Conjecture and CDC 6600 - Fortran Discourse
