What's TYPE accept
Allamarein
I found these two TYPE declarations are not welcome:
1. EXTERNAL in type is not accept
TYPE myvar
EXTERNAL :: fun
END TYPE
2. this trick is not allowed
TYPE myvec
INTEGER :: n
REAL*8, DIMENSION(1:n) :: x
END TYPE
Some workarounds is possible?
Instead of EXTERNAL you want a procedure pointer. You would then have to assign some procedure to the pointer before you could use it.
It's not clear to me what you want in the second case. Maybe:
type myvec
REAL(8), ALLOCATABLE :: X(:)
end type myvec
and then allocate X to the desired size.
Allamarein
Thank you STEVE.
I guess the pointer is the solution to my problem: could you provide an example?
The second point, using an allocatable, is the solution.
type mytype
procedure(), nopass, pointer :: mp
end type mytype
external sub1, sub2
type(mytype) :: r
r%mp => sub1
call r%mp
r%mp => sub2
call r%mp
end
subroutine sub1
print *, "I'm in sub1"
end subroutine sub1
subroutine sub2
print *, "I'm in sub2"
end subroutine sub2
If I were writing this, I would not use external but would declare an ABSTRACT INTERFACE for the subroutines and would have explicit interfaces for sub1 and sub2. The NOPASS attribute is required when there is implicit interface.
mecej4
Allamarein: I think that you are more likely to receive useful answers if you explain what your intentions are. Using pointers may solve one problem but create new problems. As to your second "trick", allocatable arrays may be a solution, but note that such arrays often need explicit allocation, and their sizes can be any positive integer. If you want to put limits on array sizes, another solution exists. If, for example, you want 3-vectors for x-y-z coordinates and 4-vectors for t-x-y-z coordinates, you can do
TYPE myvec(n)
   INTEGER, LEN :: n        ! length parameter of type
   REAL, DIMENSION(1:n) :: x
END TYPE
type(myvec(n=3)) :: point
type(myvec(n=4)) :: event
point%x = [1.0, 2.0, 3.0]
event%x = [2015.0, 1.0, 2.0, 3.0]
FortranFan
Look into the books listed in Steve's Dr Fortran blog for more details and examples for many of these aspects: https://software.intel.com/en-us/blogs/2013/12/30/doctor-fortran-in-its-a-modern-fortran-world
For your first question on procedure pointers, here is a simple example:
program p
   abstract interface
      function Ifun() result(str)
         character(len=:), allocatable :: str
      end function Ifun
   end interface
   type :: t
      procedure(Ifun), nopass, pointer :: fun => null()
   end type t
   type(t) :: foo
   foo%fun => myfun
   print *, " message from myfun: ", foo%fun()
   stop
contains
   function myfun() result(str)
      str = "Hello World!"
   end function myfun
end program p
On your second question, perhaps you are interested in parameterized derived types (PDTs)?  Look into PDTs in Modern Fortran Explained.  Here's a simple example for that too:
program p
   type :: t(n)
      integer, len :: n
      real :: x(n)
   end type t
   type(t(5)) :: foo
   integer :: i
   real :: x
   print *, " size of x: ", foo%n
   do i = 1, foo%n
      call RANDOM_NUMBER(x)
      foo%x(i) = x
   end do
   print *, " x = ", foo%x
   stop
end program p
Allamarein
I think the pointer is the right solution, despite the fact it is slightly complicated for my skills. Is it compatible with Fortran 95?
No, procedure pointers were not in Fortran 95. They were introduced in Fortran 2003. There isn't any compiler you should be using that doesn't support these.
FortranFan
No, both of the above features are post Fortran 95.
