29282 Discussions
What's "IFORT: internal error: Assertion failed (" ?
Stephan
Hi guys,
I'm using w_fc_pc_8.0.047 (command line, IA32, single-threaded targets).
What exactly does the compiler want to tell me with this message:
(There's nothing after the opening parentheses...)
Thanks for any pointers,
Stephan
It wants to tell you that it is horribly confused and that you should get it help from Intel Premier Support, being sure to attach to your support request the source being compiled and the command line used to compile it. Add any include or module files it needs.
However, you are using a compiler so old that it is unsupported, so sending it to Intel Premier Support is just going to get you advice to try a newer compiler. 9.1.025 is current. It is very likely that a current compiler will not have this problem.
