What's wrong when running the code?
hadesmajesty
I am using IVF 10.1.025. My code runs well in the debug mode (F5). But when I switch to the normal one (Ctrl+F5), the data blow up after a loop is finished.
So, what's wrong?
TimP
Have you taken the usual steps to check for bugs, including compiling with /Qdiag-enable and compiling and running with /check ?
bmchenry
New Contributor II
Be sure to check the compilation options between the DEBUG and RELEASE.
You may have changed something in DEBUG but havenot in RELEASE.
