29487 Discussions
Where can I find older versions (2021.3) of Intel OneAPI Base and HPC for LINUX
Arunkak
Ron_Green
Arunkak
Thank you Ron_Green for sharing the information.
It would be helpful, if I get the direct offline package link. Because Its asking for License information.
Ron_Green
Only licensed users have access to older version downloads.  We do not allow free downloads of older products.  Only the current version is provided for free.
Is there some particular reason that you think an older version is needed?  The latest version is backwards compatible.
Arunkak
Okay, Thanks again.
We need the old version to compile particular application (version incompatibility) .
Steve_Lionel
What problem do you have using a newer compiler? The only reason you should have an issue is if the code being compiled has errors.
