I have a new computer with a fresh installation of the base and HPC tool kits. My C# application cannot find the Fortran DLL. I suspect I am missing an environment variable, as this same problem occurred with my last new install of Fortran. The problem was solved in these forums, but I cannot find the post. Here are the Intel related variables that I have.
ADVISOR_2025_DIR C:\Program Files (x86)\Intel\oneAPI\advisor\2025.2
IFORT_COMPILER25 C:\Program Files (x86)\Intel\oneAPI\compiler\2025.2\
VTUNE_PROFILER_2025_DIR C:\Program Files (x86)\Intel\oneAPI\vtune\2025.4
Can someone tell me which variable(s) I am missing?
I finally found that old post. I had to add to the Path variable:
C:\Program Files (x86)\Intel\oneAPI\compiler\latest\bin
I will try this.
Are you trying to setup the environment? The normal was is just to use the start menu link to open a Fortran command prompt. Was that not working?
