Why can't I post longer messages?
WSinc
Is there a restriction?
This generates a spurious BREAKPOINT at line 13, for no apparent reason.
program tallyall
logical eof
integer*4 ntally,ipuz,ital(2,10),level
integer*2 nmove,moves(729)
integer*1 b(9,9),b2(9,9),boards(1,1,4096)
integer*4 BIGNUM/2140000000/
rewind(3)
ntally=0
! call read_puzzle(boards)
ital(1,1)=1
ital(2,1)=1
do level=1,10
ipuz1=ital(l,level)
ipuz2=ital(2,level)
ital(1,level+1)=ipuz2+1
do ipuz=ipuz1,ipuz2
! print *,level,ipuz
! call gengood_3x(boards(1,1,ipuz),nmove,moves)
! print *,"nmove=",nmove
do imove=1,nmove
ntally=ntally+1
! call appmove(boards(1,1,ipuz),moves(imove),boards(1,1,ntally))
ital(2,level+1)=ntally
end do
end do ! ipuz
20 print *,"ntally=",ntally
read(*,*)
end do ! level
read(*,*)
end
billsinclaol_com
I tried different "fixes:"
1) changing the name and type of ITAL to different Integer sizes
2) removing the DO loop and replacing it with Go To statements
3) commenting out almostALL the code past line 14.
(keeping the END statement)
4) changing theNAME of the variable LEVEL.
5) Putting ITAL in a COMMON block.
I still get the same result.
The breakpoint message says that subscript#1 is a zero.
You can see that itis a fixed integer.
How could it be ZERO?
WSinc
Here is the "fixed" code.
even something as bare bones as this doesn't run.
program tally8
logical eof
integer*2 nmove,moves(729),ilev
integer*8 xtal(2,10)
data boards/81*0/
! rewind(3)
ntally=0;ilev=0
! call read_puzzle("..\..\sudoku_inp.txt",boards)
! xtal(1,1)=1
! xtal(2,1)=1
5 ilev=ilev+1
ipuz1=xtal(l,ilev)
! ipuz2=xtal(2,ilev)
! xtal(1,ilev+1)=ipuz2+1
! do ipuz=ipuz1,ipuz2
! print *,ilev,ipuz
! do imove=1,nmove
! ntally=ntally+1
! xtal(2,ilev+1)=ntally
! end do
! end do ! ipuz
!20 print *,"ntally=",ntally
! xtal(2,level+1)=ntally
! read(*,*)
! go to 5 ! ilev
! read(*,*)
end
IanH
On the 13 line of code (not including blank lines in the source) you have the lower case equivalent of IPUZ1=ITAL(L,LEVEL). Perhaps the "L" should be a "1"?
Implicit none!!!
WSinc
Fortran is NOT case sensitive.
R U saying the 1 is an L? The print is so darn small.
I will try implicit NONE.
Yes, in the line quoted, the first argument is the letter l and not the digit 1. IMPLICIT NONE is your friend.
WSinc
Well, that was STUPID on my part...............
But I am wondering if there is a way to prevent that from
happening later on.
Maybe by making the print larger?
Changing the font type?
I honestly could not tell them apart.
IanH
Quoting billsincl
happening later on.
Implicit none ;)
If you are using Visual Studio as your editing environment the fonts and sizes are pretty configurable - have a look under Tools > Options, then under Environment > Fonts and Colors. The "Plain text" acts as a global default for things that are plain text (like source code), but you can customise the text for specific source elements, comments, etc with other items in the list.
Consolas is my font of choice (and may even be the default with VS these days) because its design is particularly suited to source code (0 (zero) distinguishable from the capital letter O, etc), if you are using VS2005 on Windows XP there is a Consolas font pack that you can download from Microsoft that gives you access to this font.
