Why does my program not run faster on more threads?
Xia__Brian
I've written a parallel fortran program for numerical computing based on openMP. I tested it on a workstation with 4 CPU(48 cores /96 threads in total). but I found that the time consumption did not change much when I switched the num of threads from 24 to 48. Does anyone know the possible reasons?
the program is very long and I just show its outline here:
!$ call omp_set_num_threads(Threads_num)
	   do CurrentTimeStep = StartTimeStep + 1, EndTimeStep
			Call Streaming()            !
			!$OMP PARALLEL
			!$OMP DO PRIVATE(i) SCHEDULE(guided,4)
			do i = 1, ELE_num
				if ( ELE_PML_mark(i) ) then
					 Call Collision_LBGK_PML(i)   !
				else
					Call Collision_LBGK(i)   	!
				end if
			end do
			!$OMP END DO
			!$OMP END PARALLEL
		end do
Inside the subroutine Collision_LBGK_PML(i) and Collision_LBGK(i)  there is no large DO loop
Inside the subroutine Streaming() there are several large OMP DO loop:
		do RK_i = 1, RK_stage
			!$OMP PARALLEL
			!$OMP DO PRIVATE(i,j,tmpi,face,k)
			Do i = 1, BOU_num
				Do j = 1, BouInfo(i)%FaceNum
					tmpi = BouInfo(i)%ElementID(j)	!
					face = BouInfo(i)%FaceID(j)		!
					do k = 1, Nfp
						call boundary_conditions(tmpi,face,k) !
					end do
				End do
			End do
			!$OMP END DO
			!$OMP END PARALLEL
			!$OMP PARALLEL
			!$OMP DO PRIVATE(i,j,alpha,F2E,invM_Sx_f,invM_Sy_f,invM_Sz_f,k,invM_R,face...) SCHEDULE(guided,4)
			do i = 1, ELE_num
				  do j = 1, Np
						invM_Sx_f = 0.0
						invM_Sy_f = 0.0
						invM_Sz_f = 0.0
						do k = 1, Np
						   do alpha = 1, 18
							  invM_Sx_f(alpha)=invM_Sx_f(alpha)+...
						   end do
						end do
						do alpha = 1, 18
                              invM_R = 0.0
							  do face = 1, 4
									if ( ELE(i)%n_ea(face,alpha) < 0.0 ) then
										 if ( ELE(i)%F2B(face)==0 ) then		!
											do k = 1, Nfp
												invM_R = invM_R + ...
											end do
										 else									!
											do k = 1, Nfp
											end do
										end if
									end if
							  end do
							  ELE(i)%df(alpha,j) = a(RK_i)*ELE(i)%df(alpha,j)&
													+ dt*( invM_R - ea(alpha,1)*invM_Sx_f(alpha) &
																- ea(alpha,2)*invM_Sy_f(alpha) &
																- ea(alpha,3)*invM_Sz_f(alpha) )
					   end do
				  end do
			end do
			!$OMP END DO
			!$OMP END PARALLEL
			!$OMP PARALLEL
			do i = 1, ELE_num
				 ELE(i)%f(1:18,:) = ELE(i)%f(1:18,:) + b(RK_i)*ELE(i)%df(1:18,:)
			end do
			!$OMP END DO
			!$OMP END PARALLEL
		end do
subroutine boundary_conditions does not contain large loop
ELE_num is a large integer(10^5~10^6) , so all of the loop i =1, ELE_num is parallelized
there is NO read/write operation in all subroutines
the program is compiled using Intel fortran compiler 2019 under the following setup:
optimization level: O3
favor fast code
parallelization: yes
threshold for auto-parallelization : 100
threshold for auto-vectorization : 100
prefetch insertion : agressive
interprocedure optimization : Yes
enable matrix multiply call : yes
Bruce_Weaver
Which version of Windows were you running?  I'm wondering if this is a processor group issue.
gib
New Contributor II
This may be obvious, but in my limited experience increasing the number of threads with OpenMP does not automatically result in a speed increase.  I believe that's because of bus contention(?) - the bus that's shared for memory accesses is often the bottleneck.  Posters with more knowledge can supply a better explanation.
It would be interesting to know how the speed varies with number of threads as it ranges from 1 to 24.
TimP
Running on such a large number of cores is complicated enough that with such extremely limited information we can't guess much.  You don't even say whether it makes a difference when you enable nested parallelism, but first you may want to explore the inner and outer parallel separately.  You don't reveal the results of setting omp_places=cores which is almost certainly needed, as well as testing with the threads pinned to 1 and 2 CPUs.  As you probably need to test scaling for thread numbers 1,2,4,..12... perhaps you are hinting that it's too much work to investigate, but then asking us isn't productive.
I haven't much experience with it, but I'd guess unnecessary used of guided may work better pinned to 1 CPU.
Wow, now that I have an internet service (Viasat) which doesn't go through AT&T or Verizon, I'm not blocked from reaching Intel's login server.
jimdempseyatthecove
favor fast code
parallelization: yes **********************
*** Do not mix auto-parallelization of loops with OpenMP parallelization
Use either /openmp .OR. /parallel .NOT. both
Your description sounds like you are using (attempting to use) nested parallelism. While you can do this, you also must be careful in how you nest your parallel regions. Simply enabling nested parallel regions then parallel everything generally results in severe oversubscription of threads.
Jim Dempsey
