Why doesn't this work?
styc
I have this program:
[fortran]program test
    integer i
    !$omp parallel private(i)
    !$omp single
    do i = 1, 16
        call f(i)
    end do
    !$omp end single nowait
    !$omp end parallel
    contains
    subroutine f(x)
        integer :: x
        !$omp task firstprivate(x)
        print *, x
        !$omp end task
    end subroutine
end program
[/fortran]
With gfortran 4.4, I can see a permutation of 1 thru 16. But with ifort 12.1.{01}, I see a lot of other values.
Udit_P_Intel
I believe this may be a bug in the compiler. The TASK construct is a new OpenMP* 3.0 feature and may be erroneous here. If I replace the function call f(i) with an explicit print statement surrounded by a TASK construct, then the correct values are printed.
What do the OpenMP* experts on this forum think?
Best!
-Udit
Ron_Green
looks like a bug to me. This appears to be a standard sample, I found the same code in C on the internet.
I'll start a bug report.
BUG id DPD200176160
ron
Ron_Green
Just to close this out - this bug has been fixed in the most recent 12.1 updates ( Updates 10 and 9)
ron
