29487 Discussions
Why only half of the cores are used in OPENMP
志强_赵_
I have 20 cores per node. I run codes on the machine  using OPENMP.
Why only half of the number of the cores(10) are used, while the others are sleeping?
It puzzles me a lot.
jimdempseyatthecove
Check your OpenMP environment variables relating to affinity. This would be KMP_AFFINITY, GOMP_CPU_AFFINITY, OMP_PLACES, OMP_PROC_BIND, KMP_PLACE_THREADS. And the non-affinity related settings: OMP_THREAD_LIMIT, KMP_ALL_THREADS.
The system administrator may also be able to restrict the number of (and which) logical processors are available to a process (e.g. taskset, cpuset, ...).
Jim Dempsey
jimdempseyatthecove
Are you sure you have 20 cores per node as opposed to 10 cores/20 logical processors per node? (Hyperthreading provides for 2 hardware threads per core). As to why this is important, the OpenMP environment variables can be set to limit the OpenMP thread pool to 1 thread per core (each thread can float between either of the 2 hardware threads of a core, no two thread sharing the same core).
Jim Dempsey
志强_赵_
The cpuinfo is attached. My program only use the 10 cores with physical id=0.
Jim Dempsey
