Wildcard Format Write
Nick2
I have a question about code that looks like this:
WRITE (IFIL,*) XOUT, (PLTVAL(J,I),J=1,IPTS)
XOUT and PLTVAL are either double or single precision values.
In one instance, I get a line that looks like this:
0.000000000000000E+000 128930.930924782 354.774066602473 330.477857203495 9275.40669654240 2453231.04053296 -3.88026220562964
In another instance (different project), I get a bunch of lines that look like this:
0.000000000000000E+000 64805.3993318746 0.000000000000000E+000
0.000000000000000E+000 11541.8275238493 1721980668.39294
575.247120749910 6.55100000000000 0.000000000000000E+000
0.000000000000000E+000 15572516.7609353 300.000000000000
So, which one is correct, and why the difference?
In single precision I get output that looks like this:
0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00
Seems consistent with the second example in double-precision
Thanks!
You are using list-directed formatting. This leaves the choice of formatting largely up to the implementation and you have no control of the presentation. List-directed uses different formats depending on the magnitude of the value. Also, the choice of when to start a new line is implementation-dependent.
If the format matters to you, use an explicit format.
mecej4
This is a side comment: It is misleading/confusing to call '*' a "wildcard" when used as a unit specifier in a Fortran program. The asterisk is/was used for several purposes in Fortran. Examples, some involving obsolete/deprecated usage:
REAL*4
CHARACTER*8 STR(*)
call sub(a,b,c,*2,*3) (alternate return)
In none of these cases does the asterisk have the same meaning as in regular expressions.
Arjen_Markus
In fixed form source it is also an alternative to C in the first column (comment) and
you can also use it as any ordinary character for line continuation in the sixth column.
And there are many more uses.
Arjen
