Windows API functions/sub routines list
Praveen_D_1
Hi
I want to know where i can get documentation of fortran windows api?
Praveen
Anonymous66
Valued Contributor I
Hello Praveen,
There is information in our Windows* Documentation. The easiest way to find it is to search for windows* api in the index.
Annalee
Praveen_D_1
Hi Annalee
I want to create Windows UI using Intel visual fortran 2013 in VS2010 like SplitViewers, Treeviews..etc. Could you please help where to start with. I didn't see much on UI in Intel documentation.
Thanks in advance
SergeyKostrov
Valued Contributor II
>>... I didn't see much on UI in Intel documentation... Please take a look at MSDN and it should help you to understand how to use these UI functions and controls properly.
Bernard
Here you have an example of Tree-view control ://msdn.microsoft.com/en-us/library/windows/desktop/hh298371%28v=vs.85%29.aspx
Stephen_Sutcliffe
New Contributor III
I recommend you get hold of Normal Lawrences book "Compaq Visual Fortan -  A guide to Creating Windows Applications". There are good examples of how to create Treeview/Splitter applications inside. Some minor coding changes are required if you are working in 64 bit as this book was published in 2002 and is primarily aimed at 32-bit application development. The main change is the handles need to be defined as INTEGER(HANDLE) which will work for all configurations.
Speaking from experience of trying to work from MSDN this book will save you a lot of heartache if you can get hold of a copy.
Bernard
>>>Speaking from experience of trying to work from MSDN this book will save you a lot of heartache if you can get hold of a copy>>>
Yes that's true.It reminds me the situation when I tried to write programs in MASM32 and needed to use MSDN.
SergeyKostrov
>>>>Speaking from experience of trying to work from MSDN this book will save you a lot of heartache if you can get hold of a copy>>> >> >>Yes that's true.It reminds me the situation when I tried to write programs in MASM32 and needed to use MSDN. I never had Any problems with MSDN included with different Visual Studio Professional Editions and installed on my many development computers. I don't use online MSDN at all.
Bernard
I was talking about the online MSDN,but probably it was caused by me while messing with Win32 assembly programming.
