Working with real data
Carlos_S_
Please, someone could explain me how to get a real data from an edit box, when working with Windows Applications.
Sincerely,
Carlos Santos
Paul_Curtis
Valued Contributor I
Here is code to read text from an EditBox control, and extract a REAL value.  This is the WinAPI version, where the control's window handle (hwnd) and the id of the EditBox control (controlID) are known to the caller.
SUBROUTINE EditBoxReadText (hwnd, controlId, text, textLen)
    IMPLICIT NONE
    INTEGER(HANDLE), INTENT(IN)    :: hwnd
    INTEGER, INTENT(IN)            :: controlID
    INTEGER, INTENT(IN)            :: textLen
    CHARACTER(LEN=textLen), INTENT(OUT) :: text
    INTEGER                        :: rval
    text = ""
    rval = SendControlMessage (hwnd, controlId, WM_GETTEXT, &
                               textLen, LOC(text))
	!	return value is number of characters copied
    IF (rval < 0) THEN
        CALL ControlError ("EditBoxReadText", controlId, "WM_GETTEXT")
    END IF
END SUBROUTINE EditBoxReadText
SUBROUTINE EditBoxGetReal (hwnd, controlID, argval, nulldefault)
    IMPLICIT NONE
	REAL,INTENT(IN),OPTIONAL	   :: nulldefault
	REAL,INTENT(INOUT)			   :: argval
    INTEGER, PARAMETER             :: maxchars = 40
    CHARACTER(LEN=maxchars)        :: contents
    REAL                           :: valu
    INTEGER                        :: status
    INTEGER                        :: pos, hour, minute
    CALL EditBoxReadText (hwnd, controlId, contents, maxchars)
	!	stop now if no data to convert
	pos = INDEX(contents, CHAR(0))
	IF (is_empty(contents, pos)) THEN
		IF (PRESENT(nulldefault)) argval = nulldefault
		RETURN
    END IF
	CALL CStringToFortran (contents)
    contents = ADJUSTL(contents)
	!	allow ":" as a timefield delimiter
	pos = INDEX(contents, ':')
	status = 1
	IF (pos > 0) THEN
		contents(pos:pos) = ' '
		IF (pos == 1) THEN
			hour = 0
			READ (contents, *, IOSTAT = status, END=5) minute
		ELSE
			READ (contents, *, IOSTAT = status, END=5) hour, minute
		END IF
		IF (status == 0) THEN
			SELECT CASE (minute)
			CASE (0:59)
				argval = FLOAT(hour) + FLOAT(minute)/60.
			END SELECT
		END IF
		RETURN
	!	regular real value
	ELSE
		IF (INDEX(contents, '.') == 0) THEN
			pos = INDEX(contents, ' ')
			contents(pos:pos) = '.'
		END IF
		READ (contents, '(F)', IOSTAT=status, END=5) valu
		IF (status == 0) argval = valu
	END IF
5	RETURN
END SUBROUTINE EditBoxGetReal
Carlos_S_
Dear Paul,
Thank you so much for your support! It helped me a lot.
Sincerely,
Carlos Santos.
Carlos_S_
Dear Paul,
About your suggestion, I had doubt about the subroutines ControlError and CStringToFortran. They weren´t presented in your message. Please, could you explain me what they do? Could you send them for me?
Thank you in advance.
Carlos Santos.
