Write statement cannot produce new lines within user-defined formatted I/O procedures for derived type in FORTRAN
Libin
I want to implement the user-defined I/O procedures for the derived types in my FORTRAN code. However, write statements within those procedures cannot produce new lines between two sequential write statements. The derived type is defined in FORTRAN module file as below,
module station_module
    implicit none
    character(8), parameter :: FmtFloat = '(5E15.7)'
    type :: station
        integer, private :: ns = 0
        real, public, allocatable :: xloc(:), yloc(:), zloc(:)
    contains
        procedure, public :: import_station
        procedure, public :: export_station
        procedure, private :: read_station
        generic, public :: read (formatted) => read_station
        procedure, private :: write_station
        generic, public :: write (formatted) => write_station
        final :: destruct_station
    end type station
    interface station
        module procedure new_station
    end interface station
contains
    function new_station(n) result(t)
        implicit none
        integer, intent(in) :: n
        type(station) :: t
        if (n > 0) then
            allocate (t%zloc(n))
            allocate (t%yloc(n))
            allocate (t%xloc(n))
            t%ns = n
        end if
    end function new_station
    subroutine read_station(dtv, unit, iotype, vlist, iostat, iomsg)
        implicit none
        class(station), intent(inout) :: dtv
        integer, intent(in) :: unit
        character(*), intent(in) :: iotype
        integer, intent(in) :: vlist(:)
        integer, intent(out) :: iostat
        character(*), intent(inout) :: iomsg
        call dtv%import_station(unit)
        iostat = 0
    end subroutine read_station
    subroutine import_station(this, unit)
        implicit none
        class(station), intent(inout) :: this
        character(256) :: header, footer
        integer ns
        read (unit, '(A)') header !> Header
        read (unit, *) ns
        if (ns > 0) then
            if (allocated(this%zloc)) then
                deallocate (this%zloc)
            end if
            allocate (this%zloc(ns))
            read (unit, *) this%zloc
            if (allocated(this%yloc)) then
                deallocate (this%yloc)
            end if
            allocate (this%yloc(ns))
            read (unit, *) this%yloc
            if (allocated(this%xloc)) then
                deallocate (this%xloc)
            end if
            allocate (this%xloc(ns))
            read (unit, *) this%xloc
            this%ns = ns
        end if
        read (unit, '(A)') footer !> Footer
    end subroutine import_station
    subroutine export_station(this, unit)
        implicit none
        class(station), intent(in) :: this
        write (unit, '(A)') ">STATION INFO"
        write (unit, '(I6)') this%ns
        write (unit, *) "Z:"
        write (unit, FmtFloat) this%zloc
        write (unit, *) "Y:"
        write (unit, FmtFloat) this%yloc
        write (unit, *) "X:"
        write (unit, FmtFloat) this%xloc
        write (unit, '(A)') ">END STATION"
    end subroutine export_station
    subroutine write_station(dtv, unit, iotype, vlist, iostat, iomsg)
        implicit none
        class(station), intent(in) :: dtv
        call dtv%export_station(unit)
        iostat = 0
    end subroutine write_station
    subroutine destruct_station(this)
        implicit none
        type(station), intent(inout) :: this
        end if
        end if
        end if
        this%ns = 0
    end subroutine destruct_station
end module station_module
We can see that the user-defined formatted write statement just call a regular subroutine named export_station, by which I expect the same result in both ways.
Here is my test program:
program Test
    use station_module
    implicit none
    type(station) :: pt, pt1, pt2
    pt = station(4)
    write(*, *) pt
    call pt%export_station(6)
end program Test
The output:
 >STATION INFO     4Z:  0.0000000E+00  0.0000000E+00  0.0000000E+00  0.0000000E+00
 Y:  0.0000000E+00  0.0000000E+00  0.0000000E+00  0.0000000E+00X:  0.0000000E+00  0.0000000E+00  0.0000000E+00  0.0000000E+00>END STATION
>STATION INFO
     4
 Z:
 Y:
 X:
>END STATION
The regular subroutine export_station produces what I expect. New lines are produced between two write statements, while write statement of the derived type does not.
Is it a bug or do I miss something?
Best,
Libin
Steve_Lionel
User-defined derived-type I/O is all non-advancing (and you can't change this). If you want newlines you have to write them explicitly (using a / format, for example.)
