29274 Discussions
Writing to standard output with advance = 'no'
Garcia__Javier
This short program works as intended if I compile with gfortran and the option -fbackslash, i.e., it shows a line that states the step number I'm currently in and it updates it every second.
program test
    use iso_fortran_env, only: output_unit
    character(len = 24) :: msg
    n = 10
    write(msg, '(A, I3, A, I3)') 'Step', 1, ' out of', n
    write(output_unit, '(A)', advance = 'no') trim(msg)
    call sleep(1)
    do i = 2, 10
        write(output_unit, '(A)', advance = 'no') repeat('\b', len(trim(msg)))
        write(output_unit, '(A, I3, A, I3)', advance = 'no')  'Step', i, ' out of', n
        call sleep(1)
    enddo
end program test
Instead, if I compile with ifort (with the option -assume bscc), it doesn't show anything until the program finishes. How can I get the same behavior I get when compiling with gfortran?
Thanks!
Steve_Lionel
In order to make the output available, you need to insert a FLUSH statement, gfortran and Intel Fortran behave differently here, both are correct.
So a modified program (that doesn't require a special compile switch) would be:
program test
    use iso_c_binding, only: c_backspace
    n = 10
    flush(output_unit)
    call sleep(1)
    do i = 2, 10
        write(output_unit, '(A)', advance = 'no') repeat(c_backspace, len_trim(msg))
        flush(output_unit)
        call sleep(1)
    enddo
end program test
This partially works, in that the output appears each iteration. But the backspaces never get written to the output unit, where I think they should. To fix this, add a second flush after the first write, like so:
program test
    n = 10
    flush(output_unit)
    call sleep(1)
    do i = 2, 10
        flush(output_unit)
        flush(output_unit)
        call sleep(1)
    enddo
end program test
I think it's a bug that the flush after writing the backspaces is needed - I'll report that to Intel. However, this version should also work in gfortran.
Garcia__Javier
This works perfectly for me, thanks Dr. Fortran!
Steve_Lionel
Issue 04436367 has been submitted on this. It is reproducible with this small program:
program test
implicit none
write (6,'(A)', advance='NO') 'ABCDE'
!flush(6)
write (6,'(A)', advance='NO') 'FGHIJ'
flush(6)
end
Steve_Lionel
Bug confirmed by Intel support, sent on to development for a fix.
