Wrong constructor for extended type
Daniel_Dopico
The code below gives the following error: "error #6593: The number of expressions in a structure constructor differs from the number of components of the derived type.   [TYPERESTRIC_UNITVECT]", but according to me the code should be correct.
PROGRAM wrong_constructor
    IMPLICIT NONE
    TYPE VECTOR
	    REAL(8),POINTER,DIMENSION(:)::rpt=>null(),rptp=>null(),rpts=>null()
    END TYPE VECTOR
    TYPE,ABSTRACT::typerestric
        INTEGER:: ir = -1
        INTEGER numrestrics
	    REAL(8)::penaltycoef_rel=1.d0
    END TYPE typerestric
    TYPE,EXTENDS(typerestric)::typerestric_unitvect
        TYPE(VECTOR),POINTER:: u
    END TYPE typerestric_unitvect
    TYPE(VECTOR),TARGET::u
    TYPE(typerestric_unitvect) RS
    RS=typerestric_unitvect(ir=1,numrestrics=1,penaltycoef_rel=1.d0,u=u)
END PROGRAM wrong_constructor
Steve_Lionel
The compiler seems to get confused by the two uses of "u" in the constructor. If I rename the variable to "u2" it works.  Please submit this in a bug report to Intel.
Steve_Lionel
Daniel_Dopico
Thank you very much, Steve, I didn't notice this. Moreover, it happens only with extended types, if all the variables are defined in the type without extension, the bug dissapears too.
Daniel_Dopico
Done.
Devorah_H_Intel
Thank you for your report. I have escalated this issue to our compiler engineering.
Daniel_Dopico
Thank you Devorah.
Ron_Green
this issue was fixed in PSXE 2020 Update 2, compilers 19.1.2
