29487 Discussions
Wrong/inconsistent output with g-format
Harald1
New Contributor II
Up to and including ifort/ifx 2021.2.0, the following code prints inconsistently:
% cat ifort-g-fmt-bug.f90
double precision :: x = 100., d = 0.01_8
print '(3g11.3)', x + d, x, x - d
end
% ifort ifort-g-fmt-bug.f90 && ./a.out
   100.       100.      100.0
Note that the third column should also read "100." without any decimal.  Likely an internal double rounding issue with the g format.
Harald
Steve_Lionel
Yeah, something is weird here. I note that NAG Fortran gives the "100." output you expect. This part of the standard was completely overhauled for Fortran 2018, as we felt the earlier table-based description was incomprehensible.  So I changed my mind - this is indeed a bug.
And, yes, @andrew_4619 , I did copy and paste that.
Steve_Lionel
Not a bug.
The standard says, "If the internal value is a number other than zero, let N be the decimal value that is the result of converting the internal value to d significant digits according to the input/output rounding mode and let s be the integer such that 10**(s−1) ≤ |N| < 10**s . If s < 0 or s > d, kPEw.d or kPEw.dEe editing is used for Gw.d editing or Gw.dEe editing respectively, where k is the scale factor (13.8.5).  If 0 ≤ s ≤ d, the scale factor has no effect and F(w − n).(d − s),n(’b’) editing is used where b is a blank and n is  4 for Gw.d editing, e + 2 for Gw.dEe editing if e > 0, and 4 for Gw.dE0 editing."
The value of x-d is 99.99, so the value of s here is 2 (10**1  ≤ 99.99 < 10**2). s (2) is not greater than d (3),  and s is greater than zero, so the format used is F(11-4).(3-2) or F7.1. 99.99 in an F7.1 format outputs as 100.0.
andrew_4619
Steve, I sincerely hope that you cut and pasted that answer.
Harald1
New Contributor II
@Steve_Lionel wrote:
"If the internal value is a number other than zero, let N be the decimal value that is the result of converting the internal value to d significant digits according to the input/output rounding mode"
For g11.3 we have d=3, so what is N? I would expect 99.99 to be converted ("rounded") to 100.
" and let s be the integer such that 10**(s−1) ≤ |N| < 10**s . If s < 0 or s > d, kPEw.d or kPEw.dEe editing is used for Gw.d editing or Gw.dEe editing respectively, where k is the scale factor (13.8.5).  If 0 ≤ s ≤ d, the scale factor has no effect and F(w − n).(d − s),n(’b’) editing is used where b is a blank and n is  4 for Gw.d editing, e + 2 for Gw.dEe editing if e > 0, and 4 for Gw.dE0 editing."
This is pretty clear.
My reading is that s=3 due to N=100.  The text in the standard does not seem to determine s first, it refers to N initially, which appears deliberate to avoid the possible ambiguity 100. vs. 100.0
Steve_Lionel
Barbara_P_Intel
I just filed a bug reporting this, CMPLRLIBS-33394.   ifx does the same (wrong) thing.
I'll keep you posted on the fix.
