XE 2015 Installer has no options
Andrew_Smith
Valued Contributor I
The latest installer no longer gives us options for which version of Visual Studio to install on. In fact it presents no options at all.
VS version was a useful feature because it allowed me to maintain old and incompatible compiler versions on older VS versions, keeping separation without needing multiple workstations.
When will we get better support for older compiler versions, such as being able to set compiler version as a solution property rather than a Visual Studio property ?
Andrew_Smith
I was using "Intel(R) Parallel Studio XE 2015 Update 2 Composer Edition for Fortran Windows* Installation"
Select Customize (a link in the left pane towards the end of the set of prompts) and you'll be able to select VS versions. Also see
