XEffort for x64??
DavidWhite
Valued Contributor II
A number of my applications use the XEffort set of libraries to interface to the Windows API.
A number of my clients have migrated to 64-bit MS Office, and so I need to start migrating to x64.
I gather that XEffort is only available for Win32, or has anyone ported it to x64?
If not, it looks like a long road ahead ...
David
I'm not aware of an x64 port. Since I'm now hosting Xeffort it's on my list, but I don't see having the time to do it for a while.
DavidWhite
Thanks, Steve.
While some of my apps use dialogs extensively, it looks like my immediate need is to read some registry strings and upper/lower case conversion.  I can write my own case conversion routines, but are there any alternatives to XEffort for accessing Registry, for both Win32 and x64?
David
andrew_4619
There are registry interfaces in ifwin ( advapi32). I found an very old application that I had an example of some usage, I don't know if this still works ok on w7 or x64 and it looks like some update is required but for what its worth....
subroutine regtest()
  integer*4     mode,ll,ierr,valLen
  character*256 skey,valdata,valname
  mode=1
  skey='SOFTWARE\\xxxxxxx\\yyyyyyyy\\&
        &Pages\\uuuuuu\\zzzzzzzzz'C
  valname='C:\\WINDOWS\\system32\\yyyyyy.DLL'C
  call ReadRegVar(skey,valData,valname,mode,ll,ierr)
  skey='SOFTWARE\\zzzz\\yyyyyyy\\&
        &Pages\\VERCP32\\tt0'C
  valName='Test'C;  valData='hurrah'C;  valLen=6
  call WriteRegVar(skey,valData,valname,valLen,ierr)
return
end
subroutine ReadRegVar(skey,valData,valname,mode,ll,ierr)
  use ifwin
  implicit none
  character*(*),intent(inout)::skey
  character*(*),intent(inout)::valdata
  character*(*),intent(inout)::valname
  integer*4, intent(inout):: mode
  integer*4, intent(out):: ll
  integer*4, intent(out):: ierr
  character*255 subKey, vname, strx
  integer*4 regCallStat, mainKey, hKey, l1, l2
  ierr = 0
  if (mode .eq. 1) then
    mainKey= HKEY_LOCAL_MACHINE
  else
    ierr = -2;    return
  endif
  subkey = skey
  regCallStat=RegOpenKeyEx(mainKey,subKey,0, KEY_QUERY_VALUE,loc(hKey))
  if (regCallStat .ne. 0) then
    ierr = regCallStat;    return
  endif
  vname = valname ! value name
  l1 = 0;  l2 = 256
  regCallStat = RegQueryValueEx (hKey, vname, 0, loc(l1),loc(strx),loc(l2))
  endif
  ll = l2 - 1 ! strip away null termination
  valdata = strx(1:ll)
end
subroutine WriteRegVar(skey,valData,valName,ValLen,ierr)
  use ifwin;  implicit none
  character*(*),intent(inout)::valName
  integer*4, intent(in) :: valLen
  integer*4 regCallStat, mainKey, hKey, l1, l2, valType,hNewOrOld
  ierr = 0;  mainKey= HKEY_LOCAL_MACHINE;  subkey = skey
  valType=REG_SZ
  regCallStat=RegCreateKeyEx(mainKey, loc(subKey), 0,'REG_SZ'C,REG_OPTION_NON_VOLATILE, KEY_ALL_ACCESS, NULL, loc(hKey),loc(hNewOrOld))
  if(regCallStat) return
  regCallStat=RegSetValueEx(hKey, valName, 0, valType, loc(valData), valLen)
  if(regCallStat) ierr=-1
  return
end
