Using Xcode 2.4.1 and Intel Fortran 10.1.007, COMMON blocks that are in one dylib get properly referenced from another dylib, i.e. there's only one instance of the COMMON block symbols.
However, using the same compiler/linker flags but switching to Xcode 3.0, my common blocks are no longer common - each dylib that references them get their *own* copies.
I'm not using the Xcode 3.0 IDE, all my building is done from the command line; I am using the gcc linker to link. Since this worked fine with Xcode 2.4.1, my tests point at it being an issue to take up with Apple, but I wanted to see if others have encountered the problem.
For what it's worth, I see the identical problem on PowerPC using the Absoft Pro Fortran 9.2 compiler.
Thanks, Todd.
I am loading a dynamic library and calling an entry point from within an executable. The calling program can see the common block (which it defined) but the code inside the dylib cannot see the common block.
Both the executable and the dylib are mixed C and Fortran. Both C and Fortran functions are able to see the common block in the executable, and neither are able to see it in the dylib.
I wish I had more to contribute...
- Mark
Compiling the same example using Xcode 2.4.1 will produce expected results. Perhaps there are changes I need to make for Xcode 3, but I'll contact Apple to find out, and file a bug if this is indeed an Xcode 3 bug.
-Todd
Please reporthere what you learn from Apple.
Hope this helps.
If tpeterson@spss.com is still reading, if you filed a bug willyou please post your Radar#?
Yes, Intel still supports our Fortran compiler, however, we do not have control over the OS vendors tools. In this case, the root-cause lies with the GNU linker (ld) provided w/Xcode. I will check on the status from Apple and post again if there is any news.
I am unable to show success with Xcode 2.4.1 with the example below (sans the DLLEXPORT/DLLIMPORT), so I do not know how it differs from codes reported earlier that work with Xcode 2.4.1 but fail with the newer Xcode 3.x. It would be interesting to see a sample that works with Xcode 2.4.1 if anyone has one.
As a work-around one could consider using DLLIMPORT/DLLEXPORT directives with the Intel Fortran compiler as shown in the example below. Support for these directives was added in an earlier 9.1 update. This works with Xcode 3.0 and our latest 10.1.015 update.
main.f90:
PROGRAM CTEST
!DEC$ ATTRIBUTES C, ALIAS:'_TESTSUB3' :: TESTSUB3
CALL TESTSUB1
CALL TESTSUB2
CALL TESTSUB3
CALL TESTSUB2
STOP
END
sub1.f90:
SUBROUTINE TESTSUB1
!dec$ attributes dllexport :: CMBLK1
COMMON/CMBLK1/A,B
INTEGER A,B
DATA A,B/0,20/
END
sub2.f90:
SUBROUTINE TESTSUB2
!dec$ attributes dllimport :: CMBLK1
COMMON/CMBLK1/A,B
INTEGER A,B
IF (A==0) PRINT *,'Fortran TESTSUB2, B = ',B, 'should be 20 '
IF (A==1) PRINT *,'Back to Fortran TESTSUB2, B = ',B, 'should be 21 '
RETURN
END
sub3.c:
#include
struct comstruct{
int A;
int B;
extern struct comstruct cmblk1_;
void TESTSUB3(void)
cmblk1_.A = 1;
cmblk1_.B = cmblk1_.B + 1;
printf(" C TESTSUB3, A is: %d ",cmblk1_.A);
printf(" C TESTSUB3, B is: %d ",cmblk1_.B);
Compile/link using the Intel 64 compiler and gcc as follows:
ifort -dynamiclib -o sub1.dylib sub1.f90 -Wl,-single_module -Wl,-undefined dynamic_lookup
ifort -dynamiclib -o sub2.dylib sub2.f90 -Wl,-single_module -Wl,-undefined dynamic_lookup
gcc -m64 -dynamiclib -o sub3.dylib sub3.c -Wl,-flat_namespace,-single_module,-U,_cmblk1_
ifort -o main main.f90 sub1.dylib sub2.dylib sub3.dylib -Wl,-bind_at_load
The correct results will be:
Fortran TESTSUB2, B = 20 should be 20
C TESTSUB3, A is: 1
C TESTSUB3, B is: 21
Back to Fortran TESTSUB2, B = 21 should be 21
This common block issue has been fixed in XCode 3.1. Look at the man page for ld(1) and search for the -commons switch and its treatment options: ignore_dylibs, use_dylibs, and error.
Hope this helps, Todd
-commons use_dylibs
if you'd like to send this through to the linker from gcc, just use :
-Wl,-commons,use_dylibs
This has worked for me in my small sample program I submitted to Apple to show the problem.
The Radar bug I filed was #5697630; it got closed as a duplicate of #5132652.
Todd
