29386 Discussions
Xcode 3.0, Intel Fortran 10.1.007 and FORTRAN common blocks
Todd_Peterson
Is anyone else having problems with Fortran COMMON blocks not being 'common' when compiled with Intel Fortran 10.1.007, then linked with mixed C/C++ shared libraries?
Using Xcode 2.4.1 and Intel Fortran 10.1.007, COMMON blocks that are in one dylib get properly referenced from another dylib, i.e. there's only one instance of the COMMON block symbols.
However, using the same compiler/linker flags but switching to Xcode 3.0, my common blocks are no longer common - each dylib that references them get their *own* copies.
I'm not using the Xcode 3.0 IDE, all my building is done from the command line; I am using the gcc linker to link. Since this worked fine with Xcode 2.4.1, my tests point at it being an issue to take up with Apple, but I wanted to see if others have encountered the problem.
For what it's worth, I see the identical problem on PowerPC using the Absoft Pro Fortran 9.2 compiler.
Thanks, Todd.
mmalson1
I believe I am seeing the same problem. I am using XCode 3 under Leopard.
I am loading a dynamic library and calling an entry point from within an executable. The calling program can see the common block (which it defined) but the code inside the dylib cannot see the common block.
Both the executable and the dylib are mixed C and Fortran. Both C and Fortran functions are able to see the common block in the executable, and neither are able to see it in the dylib.
I wish I had more to contribute...
- Mark
Todd_Peterson
Thanks for the feedback. I created a small example with a dylib and a separate executable - each has the same common block definition. When I build using Xcode 3, there are two different instances of the common block - if I set common block values in a function in the dylib, those values are not reflected in the executable.
Compiling the same example using Xcode 2.4.1 will produce expected results. Perhaps there are changes I need to make for Xcode 3, but I'll contact Apple to find out, and file a bug if this is indeed an Xcode 3 bug.
-Todd
Jeffrey_A_Intel
Please reporthere what you learn from Apple.
Todd_Peterson
Sure thing. My sources at Apple say they are aware of the problem and it will be fixed in an upcoming Xcode 3 release. They did not mention any timeframe.
Hope this helps.
mmalson1
FWIW I'm having the same problem in 10.1.008.
mmalson
Any word on this bug? I have not renewed my Intel FORTRAN subscription because of this bug. Is the FORTRAN still being supported by Intel? Did anyone file a bug report on Apple's website? XCode 3.0 and 3.1 have not fixed this problem...
Kevin_D_Intel
If tpeterson@spss.com is still reading, if you filed a bug willyou please post your Radar#?
Yes, Intel still supports our Fortran compiler, however, we do not have control over the OS vendors tools. In this case, the root-cause lies with the GNU linker (ld) provided w/Xcode. I will check on the status from Apple and post again if there is any news.
I am unable to show success with Xcode 2.4.1 with the example below (sans the DLLEXPORT/DLLIMPORT), so I do not know how it differs from codes reported earlier that work with Xcode 2.4.1 but fail with the newer Xcode 3.x. It would be interesting to see a sample that works with Xcode 2.4.1 if anyone has one.
As a work-around one could consider using DLLIMPORT/DLLEXPORT directives with the Intel Fortran compiler as shown in the example below. Support for these directives was added in an earlier 9.1 update. This works with Xcode 3.0 and our latest 10.1.015 update.
main.f90:
PROGRAM CTEST
!DEC$ ATTRIBUTES C, ALIAS:'_TESTSUB3' :: TESTSUB3
CALL TESTSUB1
CALL TESTSUB2
CALL TESTSUB3
CALL TESTSUB2
STOP
END
sub1.f90:
SUBROUTINE TESTSUB1
!dec$ attributes dllexport :: CMBLK1
COMMON/CMBLK1/A,B
INTEGER A,B
DATA A,B/0,20/
END
sub2.f90:
SUBROUTINE TESTSUB2
!dec$ attributes dllimport :: CMBLK1
COMMON/CMBLK1/A,B
INTEGER A,B
IF (A==0) PRINT *,'Fortran TESTSUB2, B = ',B, 'should be 20 '
IF (A==1) PRINT *,'Back to Fortran TESTSUB2, B = ',B, 'should be 21 '
RETURN
END
sub3.c:
#include
struct comstruct{
int A;
int B;
extern struct comstruct cmblk1_;
void TESTSUB3(void)
cmblk1_.A = 1;
cmblk1_.B = cmblk1_.B + 1;
printf(" C TESTSUB3, A is: %d ",cmblk1_.A);
printf(" C TESTSUB3, B is: %d ",cmblk1_.B);
Compile/link using the Intel 64 compiler and gcc as follows:
ifort -dynamiclib -o sub1.dylib sub1.f90 -Wl,-single_module -Wl,-undefined dynamic_lookup
ifort -dynamiclib -o sub2.dylib sub2.f90 -Wl,-single_module -Wl,-undefined dynamic_lookup
gcc -m64 -dynamiclib -o sub3.dylib sub3.c -Wl,-flat_namespace,-single_module,-U,_cmblk1_
ifort -o main main.f90 sub1.dylib sub2.dylib sub3.dylib -Wl,-bind_at_load
The correct results will be:
Fortran TESTSUB2, B = 20 should be 20
C TESTSUB3, A is: 1
C TESTSUB3, B is: 21
Back to Fortran TESTSUB2, B = 21 should be 21
Todd_Peterson
This common block issue has been fixed in XCode 3.1. Look at the man page for ld(1) and search for the -commons switch and its treatment options: ignore_dylibs, use_dylibs, and error.
Hope this helps, Todd
Todd_Peterson
To expound a little more on my previous reply, in order for Fortran common blocks to be common across libraries, use
-commons use_dylibs
if you'd like to send this through to the linker from gcc, just use :
-Wl,-commons,use_dylibs
This has worked for me in my small sample program I submitted to Apple to show the problem.
The Radar bug I filed was #5697630; it got closed as a duplicate of #5132652.
Todd
mmalson
I decided to try this again, and it still appears to not work. I've distilled it down quite a bit, it's just a shell script.
#!/bin/sh
rm -f sub.f90 main.f90 *.o static dylib
cat >sub.f90 <
SUBROUTINE TESTSUB
COMMON/CMBLK1/A,B
INTEGER A,B
PRINT *,'TESTSUB: location of A is ',%loc(A)
PRINT *,'TESTSUB: A = ',A
RETURN
END
EOT
cat >main.f90 <
PROGRAM FTEST
COMMON/CMBLK1/A,B
INTEGER A,B
DATA A,B/555,20/
PRINT *,'-----------'
PRINT *,'MAIN: location of A is ',%loc(A)
PRINT *,'MAIN: A = ',A
CALL TESTSUB
STOP
END
EOT
ifort -dynamiclib -o sub.dylib sub.f90 -Wl,-single_module -Wl,-undefined,dynamic_lookup -dyncom="CMBLKL1"
ifort -c -o main.o main.f90 -Wl,-undefined,dynamic_lookup -dyncom="CMBLKL1"
ifort -o static main.f90 sub.f90 -Wl,-undefined,dynamic_lookup -dyncom="CMBLKL1"
ifort -o dylib main.o sub.dylib -Wl,-undefined,dynamic_lookup -dyncom="CMBLKL1"
./static
./dylib
The output of the two programs should be the same, or at least the values of A should match. Currently the output is:
MAIN: location of A is 4295546224
MAIN: A = 555
TESTSUB: location of A is 4295546224
TESTSUB: A = 555
MAIN: location of A is 4294983984
MAIN: A = 555
TESTSUB: location of A is 4295624224
TESTSUB: A = 0
Is there an option I'm missing? I thought this was fixed.
mmalson
Oh, and BTW I downloaded the latest ifort last night.
mmalson
The -dyncom options do nothing because I spelled the common block name wrong. If I spell it right, I get errors, so disregard them.
