29651 Discussions
Xcode 5.0 not currently supported by the Intel Compilers
Ron_Green
25 October 2013 - Intel released Intel(R) Composer XE 2013 SP1 for OS* X, Update 1 today, 25 October 2013.   This compiler and all subsequent compilers will support Xcode 5 / Maverick.
If you have an older vesion compiler and need Mavericks support or Xcode 5 support you will need to upgrade to the Composer X 2013 SP1 Update 1 compiler or newer.
CONFUSED about names and versions?  Go here:  http://software.intel.com/en-us/articles/intel-compiler-and-composer-update-version-numbers-to-compiler-version-number-mapping
now outdated content:
Apple released Xcode 5.0 for OS* X 10.8 Mountain Lion 18 September 2013.
The Intel compilers currently do no support integration into Xcode 5.0.  We will support Xcode 5.0 in a future update release.  We recommend that customers NOT install Xcode 5.0 on their systems until we have support in the Intel Compilers.  At this time we do not have a date for the release of the Intel Compilers for OS* X.
ron
Zhang_X_1
What's the highest version of Xcode to support Intel Fortran 2013.0.088?
Ron_Green
For each release, there is a document named "Release Notes" that you can download quickly and read from your account at https://registraitoncenter.intel.com. ; It is also provided with your compiler installation in
/opt/intel/composer_xe_2013<_version>/Documentation/en_US  in PDF format.
For your compiler, this was officially tested against Xcode 4.4 and supports that version.  However, it may work with NEWER 4.x versions - we just didn't test against anything newer that 4.4 FOR THIS COMPILER version - and we do not guaratee or suggest that it will work with anything newer than 4.4.
Kevin_D_Intel
Composer XE 2013 SP1 Update 1 is now available for download from the Intel Registration Center and includes support for:
  • OS X* 10.8 and Xcode* 4.6 or Xcode* 5.0 and OS X* 10.8 SDK with Command Line Tools component of Xcode installed
Refer to the Product Release Notes for additional details:
http://software.intel.com/en-us/articles/intel-fortran-composer-xe-2013-sp1-release-notes
http://software.intel.com/en-us/articles/intel-c-composer-xe-2013-sp1-release-notes
