Xcode not detect fortran compiler
Jaehong_L_
I just purchased Intel Fortran 2015.3.187 for OSX. I'm using XCODE 6.4. It seems XCODE cannot detect fortran compiler. What should I do? Do I need to obtain lower version of XCODE?
TimP
The release notes should answer the question about xcode version compatibility.
Kevin_D_Intel
The Parallel Studio XE 2015 Update 3 only supports up to Xcode 6.3 (see RNs) so you will need to obtain that for now. Note that you have to reinstall Fortran after changing Xcode versions.
It appears Xcode 6.4 was released in the June 2015 timeframe so we may add support for that in our next Parallel Studio XE 2015 Update 5 in the coming months. I can check. It should be supported in the new Parallel Studio XE 2016 release later this month.
Kevin_D_Intel
Development confirmed Xcode 6.4 will be supported in the next two upcoming releases, Parallel Studio XE 2015 Update 5 and Parallel Studio XE 2016.
