compile with #ifdef
diedro
Dear all,
I would like to create a program with #ifdef and #endif compilation options  but I do not know how could i compile even tis simple hello program:
PROGRAM HELLO
IMPLICIT NONE
#ifdef PARALLEL
  WRITE(*,*) 'OPTION A'
#endif
 WRITE(*,*) 'OPTION A+B'
END PROGRAM
When I compile, I get this error:
hello.f90(4): warning #5117: Bad # preprocessor line
#ifdef PARALLEL
hello.f90(6): warning #5117: Bad # preprocessor line
#endif
Can someone explain me how to compile and activate or not activate options A and B.
Really Really thanks
Lorri_M_Intel
Unlike C/C++, standard Fortran doesn't have a built-in preprocessor. On your compilation line, add the command line switch "-fpp", as: ifort -fpp myfile.f and then you should get option "A+B". or ifort -fpp -DPARALLEL myfile.f and you should get option A --Lorri
TimP
In addition to what Lorri said, changing the file extension to .F90 will set -fpp.
diedro
Dear all,
thanks a lot for your suggestions, It saves to me a lot of time.
Thanks again
