29434 Discussions
Zero length pointer to "out of bounds" element
Jellby1
I believe zero-length pointers are allowed in Fortran, like zero-length arrays. When associating such a pointer, does it really matter what the pointed address is? Can it be out of bounds?
Case in point:
program test
  implicit none
  real, target :: a(100)
  real, pointer :: p(:)
  integer :: i, ini, fin, n
  ini = 1
  do i=1,20
    n = max(0,min(i,size(a)-ini+1))
    fin = ini+n-1
    print *,'iter:',i,'elements:',n,'limits:',ini,fin
    p(1:n) => a(ini:fin)
    ini = fin+1
  end do
end program test
The last few iterations create a zero-length pointer, formally pointing out of bounds to a(101:100). When compiling this with -check all I get:
forrtl: severe (408): fort: (2): Subscript #1 of the array A has value 101 which is greater than the upper bound of 100
Image              PC                Routine            Line        Source
a.out              0000000000405611  Unknown               Unknown  Unknown
a.out              000000000040516D  Unknown               Unknown  Unknown
libc.so.6          00007FB8EA5F4D90  Unknown               Unknown  Unknown
libc.so.6          00007FB8EA5F4E40  __libc_start_main     Unknown  Unknown
a.out              0000000000405085  Unknown               Unknown  Unknown
Is this meaningful or is the compiler being overzealous? Perhaps due to disabled optimizations with runtime checks?
IanH
The Fortran language requires that "The value of a subscript in an array element shall be within the bounds for its dimension."
Jellby1
OK, but then this doesn't cause the same failure:
program test
  implicit none
  ini = 1
  do i=1,20
    fin = ini+n-1
    print *,'items:',a(ini:fin),'sum:',sum(a(ini:fin))
    ini = fin+1
  end do
end program test
IanH
I've quoted an irrelevant fragment of the standard.  We are dealing with an array section, not an element.  For a subscripts triplet, "the sequence is empty if the first subscript is greater than the second".  For an array section "Each subscript ... shall be within the bounds for its dimension unless the sequence is empty".
It is the (superfluous here) bounds remapping list that is confusing the compiler.
Xiaoping_D_Intel
A bug report has been opened for the error in the first case.
