about precision
keremusu1
Hello!
I need to set a variable "n" which is equal to 10E21. When I declare it as a "real" number, it appears to be 9.9999998E+021, and when I declare it as a "double precision" number, it appears to be 9.999999778196308E+021.
What should I do to make n=10E21 exactly.
Double precision is good to only about 15 decimal digits. You could try quad precision (REAL(16)) which is good to 33 digits, but that will be a lot slower.
While integer values are exactly representable, assuming there are enough bits in the datatype, many decimal fractions are not.
jimdempseyatthecove
Keremusu,
You might find this insightful
program
literals
real(8) :: a, b
a = 10E21
b = 10E21_8
write(*,*) a,b
end
program literals
Jim Dempsey
I would also recommend the three-part series The Perils of Real Numbers.in the Newsletter thread.
