aligned_alloc and ifort/icc v17
Todor_K_
I have a code that wraps aligned_alloc C function using iso_c_binding in a module. This code, when compiled with gfortran v4.8 and newer, has no issues. However, compiling it with ifort (v17.0.1) produces linkage problems such as: testalign.f90:(.text+0x40): undefined reference to `aligned_alloc' .
As I understand it, aligned_alloc is part of c11 standard so there may be a switch that takes care of this.
So, the question is how to compile the code below with ifort v17?
If this is not possible, is there an Intel Fortran version that supports something like this? Of course, if aligned_alloc is not supported, then I will need to detect a compiler using some ugly preprocessor code and replace aligned_alloc with allocate.
Here's the (almost) minimal example:
module align
implicit none
public !Default access for the module is public .
    interface
        function aligned_alloc(alg, sz) bind(c)
            use, intrinsic :: iso_c_binding
            implicit none
            integer(kind=c_size_t), intent(in), value :: alg
            integer(kind=c_size_t), intent(in), value :: sz
            type(c_ptr) :: aligned_alloc
        end function  aligned_alloc
    end interface
contains
    subroutine res_align(p, n, alg)
        implicit none
        real(kind=c_double), intent(out), pointer, contiguous :: p(:)
        integer, intent(in) :: n
        integer, intent(in) :: alg
        integer(kind=c_size_t) :: aalg
        integer :: bytesz
        integer(kind=c_size_t) :: bbytesz
        type(c_ptr) :: ptr
        bytesz=n*storage_size(p)/8
        aalg=int(alg,kind=kind(aalg))
        bbytesz=int(bytesz,kind=kind(bbytesz))
        ptr=aligned_alloc(aalg,bbytesz)
        if (.not. c_associated(ptr)) stop 'error(res_align): unsuccessful allocation'
        call c_f_pointer(ptr,p,)
    end subroutine  res_align
end module  align
program test
  use align
  implicit none
  real(kind=c_double), pointer, contiguous :: parr(:)
  integer, parameter :: alg=64
  integer, parameter :: sz=399
  call res_align(parr,sz,alg)
  parr=77.
end program test
Steve_Lionel
I suggest that you write a simple C program that references aligned_malloc, build it (using gcc) with a link map, and see where the reference is pulled from.  ifort uses the gcc libraries, so you may just need to add one that isn't referenced by default.
Steve_Lionel
How do you know you're even linking to a library containing this procedure?
Intel Fortran supports !DEC$ ATTRIBUTES ALIGN on ALLOCATABLE variables.
Todor_K_
Good question. I don't. I only know that, for gfortran, the function exists in whatever gfortran(gcc) links in automatically (libc, i guess). I don't know where to look in case of intel fortran/c.
Todor_K_
As far as the Intel compiler's alignment control directives, I am aware of that. However they are compiler specific, so this is a plan B.
Steve_Lionel
Todor_K_
For the record, it turned out that on our cluster we have an ancient version of glibc (2010) installed together with the newest Intel compilers. This did not have aligned_alloc.
