I get a segmentation fault, when running the following program compiled with iford 19.0 without any compiler options on linux.
! ifort (IFORT) 19.0.1.144 20181018
program ifort_bug_recursive_procedure_optional_value_dummy_argument
implicit none
! works fine
call sub(10, 0, 5)
! forrtl: severe (174): SIGSEGV, segmentation fault occurred
call sub(10, 0)
contains
recursive subroutine sub(max, current, depth) ! iford bug if depth absent
integer, intent(in) :: max
integer, intent(in) :: current
integer, value, optional :: depth
! integer, intent(in), optional :: depth ! fixes the bug
logical :: step_in
step_in = .true.
if (present(depth)) then
if (current > depth) return
if (depth == 0) step_in = .false.
end if
if(step_in.and.(max >= current)) then
print *, current
! if (present(depth)) then ! fixes the bug
call sub(max, current+1, depth)
! else
! call sub(max, current+1)
! end if
end if
end subroutine sub
end program ifort_bug_recursive_procedure_optional_value_dummy_argument
This looks like a bug in Intel Fortran compiler, you can submit a support request: https://supporttickets.intel.com/?lang=en-US
I tested versions 12.1 and 14.0.3, they compile with a warning
warning #7937: The OPTIONAL attribute should not be used for arguments with the VALUE attribute. [DEPTH]
but the executable then only prints until 5, not until 10.
Since version 15.0.3, I do see the segmentation fault. nagfor and gfortran (at least since 5.4) work as expected, printing until 10, PGI 18.10 also generates a segmentation fault.
OPTIONAL and VALUE are allowed together if BIND is not used - there was some debate about this in the standards committee more than a decade ago (my first WG5 meeting!). However, it looks as if ifort isn't taking this into account when following the rules for how a not-present dummy argument is passed to a procedure where that argument is OPTIONAL. I agree that a bug report is in order.
