29649 Discussions
allocatable Components of derived types
ipeta
i wrote the following code to check if i can use allocatable components in derived types.
When i run the program end try to change the initial values of A(Type(Region_2D))they remain unchanged.
What is wrong???
P.S. When i use allocatable arrays of type Real, as a Derived type Component There 's nothing wrong.
module
Analytic_Geometry_Types
!---Data-Types-----------------------------------------------!****************************************************
!*Point 2D*
Type :: Point_2D
real :: x
real :: y
End Type
!*Vector2D*
Type :: Vector_2D
Type(Point_2D) :: i
Type(Point_2D) :: j
End Type
!*Region2D*
Type :: Region_2D
integer :: Sec_Number
Type(Vector_2D),allocatable,Dimension(:) :: Sections
end Type
end moduleAnalytic_Geometry_Types
program main< /FONT>
use Analytic_Geometry_Types
Type(Region_2D) :: A
allocate (A%Sections(3))
A%Sec_Number = 3
do I=1,A%Sec_Number
A%Sections(I)%i%x=1.0
A%Sections(I)%j%x=1.0
A%Sections(I)%i%y=1.0
A%Sections(I)%j%y=1.0
enddo
stop
end
Message Edited by ipeta on 06-15-2004 10:39 AM
You're using an undeclared and uninitialized variable Sec_Number in the DO loop.
ipeta
in the original message i wrote by mistake
do I=1,Sec_Number
in my code the statement for the do loop is:
do I=1,A%Sec_Number
but even if i write
do i=1,3
i cannot change the initial values of A
It works for me in a recent version of the compiler.
