29653 Discussions
allocatable automatic stack heap
Alessandro_D_
Dear users,
I would like to sort an array in ascending order and then sort another array according to the first. To clarify the problem, I post a simple example below. The problem is that if I need a large array (say n>=140000 in my case), I get a stack-overflow error at the line "arr2 = arr2(ind1)". Following a previous suggestion of Steve, I set the option Heap Array equal to 0 but I still get the same error. Of course I could replace the line "arr2 = arr2(ind1)" with a do-loop but I would like to avoid that.
Any comments or suggestions are welcome.
Code:
program main
use toolbox, only: sort
implicit none
integer :: n, i
real(8), allocatable :: arr1(:), arr2(:)
integer, allocatable :: ind1(:)
write(*,*) "Enter integer n, num. of elements of vectors"
read(*,*) n
allocate(arr1(n), arr2(n),ind1(n))
!arr1 = [12.0, 3.0, 14.0]
!arr2 = [10.0, 2.0, 5.0]
CALL RANDOM_NUMBER(arr1)
CALL RANDOM_NUMBER(arr2)
call sort(arr1,ind1)
arr2 = arr2(ind1)
deallocate(arr1,arr2,ind1)
end program main
Steve_Lionel
I took your code and made it executable. I determined that without /heap-arrays, I got a stack overflow, but with it, the program ran to completion. Please do a rebuild of the project with that setting. If the problem persists, put the buildlog.htm into a Zip file and attach it here.
Alessandro_D_
(I do not include the file for the toolbox that contains the subroutine sort since it is very long and not really relevant for the problem)
Steve_Lionel
Alessandro_D_
Hi Steve,
thanks for your answer.  I managed to run the program successfully by setting /heap-arrays0 (which is equivalent to /heap-arrays, right?). I wonder why /heap-arrays0 is not the default option. Is there any performance penalty if you store all arrays on the heap?
Steve_Lionel
Yes, /heap-arrays0 is the same as /heap-arrays. There is a small performance penalty, which is why it is not the default, though other compilers I know do make this the default. It matters only if array temps are created frequently in the program, but the alternative is that the program doesn't run at all.
Intel's attitude is that its compilers are for maximum performance, and a default that slows down benchmarks even a bit is frowned upon. This is not absolute - the Intel compiler did change the "realloc_lhs" default to match the standard after competing compilers made the same change.
Are you saying that putting in "0" in the property page for Heap Arrays didn't work?
Alessandro_D_
It did work, thanks! I also compiled it from the command line with either /heap-arrays or /heap-arrays0 and it works well.
