29383 Discussions
application failed initialize properly (0xc0000142)
jesusfv
Hi:
I recently re-installed Intel Fortran Compiler (Integration for Microsoft Visual Studio 2005, 10.1.4159) in my laptop after a Windows Vista meltdown.
My old installation run smoothly. In the new installation, I can compile and run a simple "hello world" program.
However, when I call the IMSL library, I can compile but, at running time, I get the message
I saw in the forum an old thread discussing this issue, but the conversation ended without a final resolution.
My options>fortran>executables reads (after the other lines):
C:Program FilesIntelCompilerFortran10.1.024IA32Lib
C:Program FilesIntelCompilerFortran10.1.024IA32Include
C:Program FilesVNIimslfnl600IA32Lib
C:Program FilesVNIimslfnl600IA32includeDLL
C:Program FilesVNIimslfnl600IA32includeSTATIC
Any help will be most useful. I have been struggling with this problem for two days
J
The list you show above is not used when applications are run - that's just for building. The key is what is the value of the PATH environment variable.
Does it work if you link to the static (not DLL) IMSL libraries?
jesusfv
Hi:
I copied the information relating the executables because I read in the help section "Specifying Path, Library, and Include Directories":
"Executables: the directories to be searched for executable files. (Works like the PATH environment variable.)" and in the old thread there was a discussion about PATH.
With the static call:
include 'link_fnl_static.h'
I cannot compile. It was next on my list of problems, but less important because I prefer the dll. Can these two problems be related?
J
What problem do you get when you use link_fnl_static.h? If it is a series of undefined references from the linker, add this line:
!DEC$ OBJCOMMENT LIB:'libguide.lib'
