are include statements in subroutines safe for mutithreading?
William_G_
HI
This may the the first of many questions about running or rewriting an application with
ThreadModel Free  ( the application works fine in ThreadModel Apartment)
I upgraded to visual fortran compiler XE 15.04.221 , but still using IA-32 build.
I have read that COMMON blocks are a problem for multithreading because they can
lead to racing , is that correct??
So when now passing arrays between subroutines on the subroutine argument list
instead of in common blocks, does the use of include statements in subroutines
to dimension arrays on the subroutine argument list, or to dimension arrays
local to the subroutine cause racing, or is it threadsafe??
Example
apple is an include with two parameter statements
INTEGER, PARAMETER ::NPCOUNT =405
INTEGER,PARAMETER :: KREAL = 355
So then are these ok to do, the first subroutine dimensions an array on the calling list with the include parameter value,
the second subroutine dimensions a local array in the subroutine with the include parameter value....
SUBROUTINE Fort01(MAIN1)
INCLUDE 'apple'
DIMENSION MAIN1(NPCOUNT)
RETURN
END
and
SUBROUTINE Fort02(MAIN1,IMAIN1)
INCLUDE 'apple'
DIMENSION MAIN1(IMAIN1)
DIMENSION LOCAL1(KREAL)
RETURN
END
BIll
Lorri_M_Intel
Include files are read only at compile time, not run time and therefore a multi-threaded application has no effect one way or another.   And, PARAMETER statements have compile-time values ONLY, and also are not affected by a multi-threaded application.
The issue with COMMON variables in a multithreaded application is that they are global, shared data, and the "usual care" must be taken when multiple threads are accessing the SAME memory locations.
           Does this help at all?
                                   --Lorri
William_G_
HI Lorri,
yes, I think your reply is helpful to me. Thank you.
I will continue organizing a few subroutines to see
how the application is behaving for me after the commons have been
eliminated, and see what happens next
thanks
bill
